So now that Winter is here.......
Has anyone got any Winter projects lined up? Restoration, servicing, repairs or replacements?
I know I have a ped to get running and some running repairs to Kims mx5.
Anyone else???
Anyone else???
Re: So now that Winter is here.......
My first project is to refit the quilted liner into my jacket.
Went out on a quite spirited memorial run yesterday and was feeling the cold, especially in the early morning mists.
Just general maintenance really to the bikes and get more ped performance!
Then just looking for track bike for next year. Besides this I havent any real plans
but then if something turns up then all could change
- First Name: Darren
Turn the tl1000r into track bike had it running just got to make an exhaust for it and junk all the road gear.and finally finish jo's gsxr just need to bleed front brakes and fit front mud guard and full fluid service. Think I done everything to the ten but....sure I can think of something.
IT'S ONLY METAL HIT IT HARDER !!!!!!!
Take off the Chrome sides of the CB13's engine (If I can get them off without wrecking the bike), and re-lacquer them or clean them up. Just gota figure out how.
Also need to repaint the left hand black crank cover of the gsxr engine. What's a good paint to use? It doesn't have to look fantastic, just protect the engine....
Apart from all this, getting some decent light in the garage would be a good starting point!
I've always found PJ1 engine paint to work wellKata wrote: Also need to repaint the left hand black crank cover of the gsxr engine. What's a good paint to use? It doesn't have to look fantastic, just protect the engine ......
- cornishredbaron
- First Name: peter
for me its a full suspension service and set up on my R1
you only get one shot at life so do it with a smile on your face
Winter job list
Bloody good clean after wet Thruxton
Change tyres and scrap rear wet and slick used at Thruxton
Replace chain
Fit seal kit to clutch master cylinder swopped at Combe
Oil and Filter change
Clean Air filter
Fit Samco hoses
Add Antifreeze
Measure front pad wear
Fit new seals to front callipers
Clean out tank
Measure clutch plates
Repair Zeus fixing on top fairing
Repair scuffs on belly pan
Repair seat unit and re-align
Make additional support for end of seat unit
Change brake line elbow unions into dry break joint for straight female
Measure swing arm length on 41t gearing
Check wheel alignment and mark offset on swingarm
Source carbon engine covers from Chem if still available
Get spare set of SBS Dual Carbon pads
Get spare CRC seat unit
Get spare clocks
Make up 3 sets of captive front wheel spacers
Get MCT to fit hydraulic preload adjuster if not total rebuild
Nut & bolt check
Look for goodies...
Replace chain
Clean Air filter
Fit Samco hoses
Add Antifreeze
Clean out tank
Get spare clocks
Nut & bolt check
Look for goodies...
- Dingle
- First Name: Sir
Occasionally remove the house dust from the R1 (she lives in my kitchen)
Oh and clean, service and bring back into life the Bandit 12 as she hasn't been on the road for a few years now and she is my steed for both the Le Mans Moto Gp & the TT in 2015.
Both taxed & MOT'd, and just normal odd maintenance jobs to do to either of them
