Weird Electrickery
Weird Electrickery
Post by MellowYellow » Oct 10th, '18, 18:03
Pal of mine has restored (from a pretty ropey state) a '72 Honda 350 twin. He knows what he is about and is pretty good with electrics.
Bike is now on the road, and other than some crap in the petrol system it goes very well.
PROBLEM : -
Indicators work with ignition on but engine not started.
They don't when the engine is running.
Help preeeeshiated folks. :-? :-? :-? :-?
Ruffian
Re: Weird Electrickery
Post by Ruffian » Oct 10th, '18, 18:23
Do you have a wiring diagram for the bike?
Has it been cut about at all??
podrick
Post by podrick » Oct 10th, '18, 19:05
He may have used a positive as a negative, many switched positives become negatives when 'off'
If that is the case he would have positive and both sides of the circuit therefore no return circuit.
Hope that makes sense ??
Jug_Inspector
First Name: Richard
Post by Jug_Inspector » Oct 10th, '18, 19:19
Can't be that as the only thing that has changed, between ignition On and engine running, is the voltage in the loom.
I would look for bad earths.
Look at the voltage drop difference across the indicator circuits when working and when engine running.
Can't be more specific about where to test without seeing a circuit diagram.
Post by MellowYellow » Oct 10th, '18, 19:35
MikeZ
First Name: Mike
Post by MikeZ » Oct 10th, '18, 20:29
What about the horn. If that is the same then problem is before that junction. If horn ok then problem after that junction. But often with d stuff it is the ignition switch contacts are worn, try a different ignition switch, i have a good one lying around you could borrow if u like, but best bet is to strip and examine and clean up contacts inside switch, they're pretty easy to work on.
MikeZ
First Name: Mike
Post by MikeZ » Oct 10th, '18, 20:30
Sorry typo: "With old stuff"
Post by Mervin » Oct 10th, '18, 20:40
Cherck the wattage required for the bulbs the 70, s Yamaha RD,s will only work with 27w bulbs using the original flasher unit
Jug_Inspector
First Name: Richard
Post by Jug_Inspector » Oct 10th, '18, 21:16
I'll have a proper look tomorrow when I'm back on my PC but for now I'd think it's likely a regulator or rectifier issue. Has the voltage level been tested when the engine is running?
Post by MellowYellow » Oct 11th, '18, 08:05
Thanks for all that.
Will pass on the wisdom later. Chap is 76 and not in the best of health, so isn't compos mentis until a bit later on.
