Been and gone and made a mess of my subframe by overtightening a nutsert, as far as I'm aware it's magnesium (2014 R6) what's my best option here please?Fao ruffian
Fao ruffian
Re: Fao ruffian
Chances are it's a magnesium alloy in cast.
Got a chance at welding it up, or if its past a structural point then it wont really matter.
The other thing would be to clamp it tight and put a brace alongside it drilled and bolted alongside.
Options are there and depends on where it is on the subframe etc. Wider pictures could help.
Or the other option of a second hand subframe.
Re: Fao ruffian
If the plastic rear fairing covers it up then you could just use a smaller nut and bolt with a couple of washers as I'm guessing the insert is spinning now? Obviously that's if Ruffian doesn't sort you out with the old glue gun
Link to all my drifting shenanigans, motorbike track days and a few 'how to's....
https://www.youtube.com/channel/UCfKNYG ... REP05rR1bA
Re: Fao ruffian
the nutsert is in TIGHT, I was hoping to drill it out,weld or repair the crack,then reinsert a new nutsert, "gently" the sert is for my seat unit so it'll come under a lot of movement from me shifting around in the seat
Re: Fao ruffian
ill post up some better pics as soon as i can, at the moment this website wont allow me ????
Re: Fao ruffian
http://www.trackdayriders.co.uk/tdr/for ... 75848.html
Haven't been able to upload anything on here for two days
link for you Ruffian with a wider view
Re: Fao ruffian
Hindsight is a wonderful thing and should have used an alloy nutsert.
Personally as I have the gear I would pull the subframe. Clean it up and well the crack and the nutsert area to thicken that mount then just drill and tap the fresh alloy weld.
