Aaarrgghh whilst commuting the warning lamp illuminated yesterday on way in...
Checked Coolant level - OK
Checked fan cutting in - OK
went out again when moving and not sat in traffic
Radiator not warm all the way through....
so next weeks week off will consist of NOT chrimbo shopping but removing Radiator and flow testing and thermostat.
Anybody any experience of getting one recored seeing as a new one is aprox £400
CBF 1000 Temp warning lamp
Re: CBF 1000 Temp warning lamp
Yea mandy at exeter radiators can recore most things, and good quality vains,
Prob just a stuck thermostat though as your bike isnt that old is it,
Usless water pump has packed up?
It will be thermostat for sure......a radiator does not suddenly block up [unless it is something big].....before you spend loads of money, if your not sure its a jammed thermostat, just remove it and run bike without it and see if you get flow through rad or not.....bare in mind it will not be as hot to touch without therm.
- goatpants
- First Name: Chris
skippy wrote:It will be thermostat for sure......a radiator does not suddenly block up [unless it is something big].....before you spend loads of money, if your not sure its a jammed thermostat, just remove it and run bike without it and see if you get flow through rad or not.....bare in mind it will not be as hot to touch without therm.
Trouble is...........
Heater wont work
Get me coat................
Seriously though, if there is an ecu program available for your bike, there may be an option to get the fan to cut in earlier. I use tuneecu on my trumpets and this is possible.
ok all sorted..air lock in system!
Radiator had beed suffering with slight leakage for a little while...
Radiator removed and repaired now refitted and bled system
whilst refitted fitted a rad guard as well..
Really happy to be bck on my bike again today, even with it pi55ing down
Good to here bikes all fixed mate
