Any one know anything about these suit case style genies mine not running to good or know anyone that can fix it
Thanks
kipor generator
- Tractorwackyracer
- First Name: mark
kipor generator
Tractorwackyracer
Re: kipor generator
Is it the mechanical or the electrical side thats playing up Mark?
The mechanical side should be just like any other petrol lawnmower/mixer/generator engine - fuel in via carb, ignited via a sparkplug, so check the usual .... sparkplug ok, fuel ok, no crud in carb, clean air filter, etc., ....
Electrical side? gawd knows ..... check brushes etc., and give it a clean up would be about my limit
- Tractorwackyracer
- First Name: mark
Re: kipor generator
Thanks moose will check plug it's a bit hit and miss t b h I think it's more electrical it's not used very often drained petrol out and put fresh in topped up oil as I know the cut out switch can be temperamental
Thanks Mark
Thanks Mark
Tractorwackyracer
- Tractorwackyracer
- First Name: mark
Re: kipor generator
Ok so cleaned plug it ran for two mins and cut out and I couldn't start it again f f s
Tractorwackyracer
Re: kipor generator
There is a generator repair centre in Teignmouth if that's any help.
