Honda cb125t engine
- Gas head
- First Name: Andy
Honda cb125t engine
My sons piston has come off the con rod and trashed the barrels and crank. Don't suppose there are any old engines or parts available on here? Bloody thing was still running with the piston off!!!
utg
Re: Honda cb125t engine
Aha i was gona sayb those Chinese engines are pretty cheap if there is one that fits , but they appear to be around the £600 mark now
https://www.chinesemotorcyclepartsonlin ... gory_30416" onclick="window.open(this.href);return false;
not Chinese, it's from the 80's. An original old bike not a knock off
- Gas head
- First Name: Andy
Think there is an original on e bay that I can get hold of. Hopefully easy to fit.
utg
tried gumtree?
It's a 125cc so can't be too bad to swap over.
Why not rebuild the original motor
The hardest bit will probably be the crank, as usually the barrels can get bored and if needed relined.
Pistons and gasket sets would all be available aftermarket
David Silver are usually good for most Honda parts -
HTTPS://www.davidsilverspares.co.uk/CB1 ... REAM-1982/" onclick="window.open(this.href);return false;
The TC was the "Superdream" version wasn't it? The basic engine is very similar to the TA & TB as well as the CD125T Benly, if you want to widen your search (though you may have to paint some parts black).
A TA or TB engine would be a good swap if you can find one, as they were 16-18bhp rather than the Superdream 12bhp ....... Though you may have to forgo the electric start .........
- Gas head
- First Name: Andy
Thanks for the help. Think I have managed to track down a replacement engine now.
utg
