990 super duke oil change
bkingalan
First Name: Alan
Post by bkingalan »
My son has done a oil change on his 990 changed the oil filter etc when he started it it won't get oil pressure up he's checked the filter is seated corectly witch it is but still won't pick up pressure.
He's done it loads before and he's not a part time bodge it type he's a aircraft tec
Anybody got any ideas ment to be riding to IOM Friday
MV 1000 brutale rs
MV 800 turismo veloce luso
bkingalan
First Name: Alan
Re: 990 super duke oil change
Post by bkingalan »
Apparently the oil pump is pumping the oil to the res tank but it's not flowing out again
MV 1000 brutale rs
Ruffian
Post by Ruffian »
Is there a pressure release valve or one way valve in the reserve tank to the engine?
Are you sure there is no pressure is manual pressure gauge or just working on the oil light?
Jug
First Name: Richard
Post by Jug »
I'd say to check the anti-drain back valve that is at the top of the pipe that connects to the bottom of the oil tank.
Check its' screen isn't blocked and also that the valve isn't jammed.
Also check the oil screen on the opposite side of the engine to the filter.
Did he drain both the sumps fully?
bkingalan
First Name: Alan
Post by bkingalan »
Thank you all he did the screen ect was going to check the valve this morning it seems the the most likely.
MV 1000 brutale rs
Jug
First Name: Richard
Post by Jug »
bkingalan wrote:Apparently the oil pump is pumping the oil to the res tank but it's not flowing out again
How so?
If the sump oil had been drained beforehand, and the fresh oil isn't getting into the engine. How is oil being returned back to the oil tank?
The new oil must be getting through surely, or the engine would quickly become dry?
Two sumps may Help for a while
bkingalan
First Name: Alan
Post by bkingalan »
He put bike over on a angle & put 1/2 a litre in through the filter & put the cover back on it pulled that oil up to the res then looses pressure again , the check valve seems free & clean today he's been to our local bike garage checked everything again no luck took the pipe off the res & gravity feed the pump through a funnel all worked fine put back together will only keep pressure above 2k going to try a new check valve tomorrow to see if it is restricting the flow in some way ..
MV 1000 brutale rs
Ruffian
Post by Ruffian »
He hasn't taken the pipes off the resivour has he??
If so there isn't any way he has put the pipes on the wrong way round or anything?
Usually it can be something simple
bkingalan
First Name: Alan
Post by bkingalan »
Update , Mike came here tonight to have another go he spoke to a ktm tec today he said take the guts out of the check valve and try it when we putting it together oil started leaking from the bottom of the res (no check valve) he had put a new jubalea clip on because it didn't feel tight enough and it was to heavy and didn't seal tight and was sucking a bit of air so wasn't drawing enough to open the check valve result perfect
You said it would be something simple ruffian
Thanks for all sugestions people !!!
MV 1000 brutale rs
