Bike stuttering
r1dave
First Name: dave
Bike stuttering
Post by r1dave »
Hi all anyone know who can fault find my zx10r started stuttering it done it before but felt liked it cleared itself but no went out yesterday stuttered then stopped started got it home will need reading machine which I don't have thanks
Re: Bike stuttering
Ruffian may be able to help with the obd reader if there's a port on it.
DID the lights go out?
Checked the battery connections?
Have you done any Work to it recently that may have resulted in kinking a pipe?
r1dave
First Name: dave
Re: Bike stuttering
Post by r1dave »
Just came to a stuttering halt but started up ok dropped dan of and in a bit of rage took it out seemed fine but at normal to lower doped can feel it judder
Millsyboy
First Name: Paul
Re: Bike stuttering
Post by Millsyboy »
fuel pump?
r1dave
First Name: dave
Re: Bike stuttering
Post by r1dave »
Millsyboy wrote: May 8th, '18, 15:19fuel pump?
yes paul have to look at a few things process of elimination spark plugs coil pack crank sensor pump etc :roll:
Re: Bike stuttering
When it stopped did it have any other issues??
Usually kawasaki fuel pumps have a teabag filter on them and these can block up if left for a prolonged time.
Has anything else been changed recently?
When was the last time it had a set of plugs?
If a coil pack was failing usually they would have a fault code.
Is it stuttering under load or idle? Cold or hot?
Anything more you can tell could help diagnose it.
Tractorwackyracer
First Name: mark
Re: Bike stuttering
Post by Tractorwackyracer »
Happened to mine it was the rectifier
Tractorwackyracer
r1dave
First Name: dave
Re: Bike stuttering
Post by r1dave »
Ruffian wrote: May 9th, '18, 19:09 When it stopped did it have any other issues??
pmd
r1dave
First Name: dave
Re: Bike stuttering
Post by r1dave »
Tractorwackyracer wrote: May 9th, '18, 19:27 Happened to mine it was the rectifier
thanks mark
Ducaki
First Name: Nige
Re: Bike stuttering
Post by Ducaki »
First thing would clean and treat all the connection plugs. My mates zx10 would always throw up the fi light with stale fuel.
