Satnav driving me nuts.
Look in here for 'How to' guides that have been donated to us...
Crusader Sport
First Name: Steve
Post by Crusader Sport » Jul 28th, '20, 14:11
Putting in the town waypoints for 9 Aug fun ride. All ok till I get to Ivybridge then after putting in the waypoints for the Southern part of the ride the satnav ignores them and takes the shortest route to the end point of the ride. Spent hours on this trying different settings including a reset to factory specs. No difference. HELP please.
2019 Bonnie T120 with Motone X Pipe
Re: Satnav driving me nuts.
Post by billinom8s » Jul 28th, '20, 16:59
Just follow the Bike in front.
That's all I'm doing. :)):
Zx10r trackbike, WR250
Ming
First Name: Andy
Post by Ming » Jul 28th, '20, 18:23
That's great advice.
Unless you're the run leader.... :))
Jug_Inspector
First Name: Richard
Post by Jug_Inspector » Jul 28th, '20, 19:03
What sat nav have you got and how are you imputing the way points?
Post by TLS-Moose » Jul 28th, '20, 19:05
If you're the run leader it doesn't matter either - everyone follows you, so as long as you don't share the exact route in advance, give the outward appearance of knowing where you're going, & retain an air of confidence, who's to argue with you? :-bd =)) =))
Post by MellowYellow » Jul 28th, '20, 19:36
Known as 'méthode nomatique'.
Post by billinom8s » Jul 28th, '20, 20:38
I knew I forgot something.
Post by menzies3032 » Jul 29th, '20, 08:14
Have to say I am kind of with Moose on this one as long as you get where you want to go and don’t end up trying to ride up a farm track with more grass then tarmac then think your all good
However to try and help answer your question it depends on the sat nav as they are all slightly differant. But you need to choose your way point carefully else they will not be serving a purpose. Also there is normally a choice on the route settings if you want the shortest, fastest most direct might want to play with these setting to see if this helps.
Living in Teignmouth
Follow me on YouTube - https://www.youtube.com/channel/UCDMdBs ... TR70_NBKjA
Crusader Sport
First Name: Steve
Post by Crusader Sport » Jul 30th, '20, 19:59
Garmin 595. I was putting waypoints in using "add location" which were ignored AFTER saving the trip. I have tried the different " route settings" to no avail. Following bike in front is a genius idea, of course if the drop off system has blown up ( like on Sunday) the TEC ends up on the way to bloody Plymouth.
Jug_Inspector
First Name: Richard
Post by Jug_Inspector » Jul 30th, '20, 21:38
Use Garmin Basecamp.
It's free and uses the maps that are in your Sat nav.
Plan the route in Basecamp then send it to your device as a track.
Then either tell your device to follow that track as a route or just show the track on the screen so you can at least see where you should be going,
royb
First Name: Roy
Post by royb » Jul 31st, '20, 07:58
Where's your sense of adventure Robert; It's more fun, and certainly beats speed traps on main roads.
Back in the room I can't even see my satnav in sunshine, and cannot hear the ruddy thing either.
Crusader Sport
First Name: Steve
Post by Crusader Sport » Aug 1st, '20, 09:37
Went to Lynton yesterday and figured it out in the car park. Added bonus I had a go at car driver parked in bike bay then warden turned up and nicked the rest, happy days. Thanks for all your help.
Jug_Inspector
First Name: Richard
Post by Jug_Inspector » Aug 1st, '20, 10:40
Did you then go on to Combe Martin?
Crusader Sport
First Name: Steve
Post by Crusader Sport » Aug 2nd, '20, 10:34
Nope, went back via Simonsbath ,Dulverton ,Tiv then back to civilisation in East Devon. On way to Lynton wanted to go on that brill road from Tiv to Witheridge but the road was shut so got to With via Rackenford. Not going that way again, went through pot hole central on lanes.
