javascript
javascript
have just changed my antivirus from mcfee to norton the problem is now when i go to get in my emails it won't let me because it says the javasrcipt is disabled, cheers gaz
new mob no. 07714415952
Re: javascript
open web browser
then
click on tools
then
Manage add ons
then click enable on Java
Done
then
click on tools
then
Manage add ons
Done
PS3 name lesnage
PS3 name lesnage
Re: javascript
cheers have gone through that and the javascript is enabled but still getting the same message
Re: javascript
You could try downloading and installing it again, you can get it here:
http://www.java.com/en/download/index.jsp
Re: javascript
cheers m8 tried that the javas there just not coming up on my browser will have to wait till friday to speak to mcfee as they only work till 5
Re: javascript
Quite possibly you got a small drop down message at the top of your screen after the changeover notifying you to allow it and you didnt see it or ignored it, this happened to me on another website that uses java and i couldnt access the forums at all, then i did a reinstall,reformat and noticed this little pop up and allowed it and after that i got access no problem so it maybe that a full reinstall will be the only option to regain it........
- BladeMan
- First Name: Mark
Re: javascript
Have you gone into add/remove programes and removed macfree? as they will conflict.
Re: javascript
sorted now when i removed mcafee they leave a couple of files you cant remove, phoned them up and they tried telling me just a coinecidence after a bit of shouting they directed me to a site that would remove the files, job done everything right again
Re: javascript
LOL, Norton is just as bad if you ever decide to change again there is a Norton removal tool as well because it is notoriously hard to get rid of on a PC, best thing to do is a reformat and full windows reinstall then you know you are clean.........gazkwak wrote:sorted now when i removed mcafee they leave a couple of files you cant remove, phoned them up and they tried telling me just a coinecidence after a bit of shouting they directed me to a site that would remove the files, job done everything right again
Re: javascript
Hi all,
I was facing same type of problem. Before asking to the forum I decided to go through the forum.
And I got my solution. After gone through this forum I have installed Avast.
Will it create any problem?
Thanks in advance.
Thanks in advance.
[url=http://www.r4i-kaart.be]buy r4 ds[/url]
