Linking TomTom to battery
Kata
First Name: John
Post by Kata » Aug 10th, '17, 12:39
Hi All,
Bought a Tom Tom 420. Comes with a lead coming from the mount with 2 pins. This is supposed to be plugged into a longer lead that has 2 wires on the end which I guess you have to wire to the battery.
I've already got a lead coming (TM type) from the battery for the battery charger.
Does anyone know of a lead that will convert between the TM type and the TomTom 2 pin socket?
Ta muchly
Re: Linking TomTom to battery
Post by Mervin » Aug 10th, '17, 18:31
You should be able to find summat here to do what you wanna do i reckon
http://www.vehicle-wiring-products.eu/s ... connectors" onclick="window.open(this.href);return false;
Ruffian
Post by Ruffian » Aug 10th, '17, 20:19
Realistically if you want it hard wired to the bike it should be done via a relay to prevent battery drain when not being used.
If you know what shape the plug is its easy,
( for example oxford heated grips now use tamiya battery plugs)
And are cheap connectors online
