Failed MOT
Maver-Nick
Failed MOT
Post by Maver-Nick »
:evil: Took her in for MOT yesterday... :roll:
Failed on front brake caliper binding, now as this has already been overhauled, and due to going through brake pads at the rate of every 3 months...I said put new ones on.
£95 + vat... :shock: so that's yet another bleeding £160 odd MOT... :cry:
And advisory note... Chain and sprockets worn to near excess... :cry: Does it ever end... :?
OUCH :!:
jason
Post by jason »
there are cheaper hobbies about it must be said....
:shock: That seems somewhat excessive pad wear :? I can't beleive you are doing 10k+ miles in 3 months, which pretty much ANY brake pad should be capable of giving ?
Sounds like you've been riding around with your brakes on too much :wink:
Maver-Nick
TLS-Moose wrote::shock: That seems somewhat excessive pad wear :? I can't beleive you are doing 10k+ miles in 3 months, which pretty much ANY brake pad should be capable of giving ?
Why you no read whole post...Sirry irriot... :roll: :wink:
Maver-Nick wrote:: front brake caliper binding
ZXR400Lee
Post by ZXR400Lee »
Mine passed with a rear brake caliper leaking, and the rear tyre being too wide, which caused the caliper steady arm to melt one side of the tyre, and the chain to melt the other side. Plus one of the front discs is lose?! ... Now.. I wont tell you where I got it done too, but I noticed these things when I turned up to the MOT centre and as you do, give your own bike a look over.. I didnt say anything but it passed.
I've now sorted these problems out, but it could have been dangerous.
duane hall
failed mot
Post by duane hall »
had taken my tl1000r to a garage and they failed it on my rear pipes and front bearings .
ok i understood about the bearings.
but a friend told me to take it there as his passed with his loud pipes on :evil:
hi hows it going
CBR_LOVER
Post by CBR_LOVER »
I'm not looking forward to MOT time as we're having
front brake binding problems on the CBR,stripped 'em all down and been through em,and can't find anything obvious wrong with them.....mind,it ain't that straight forward with it's linked brakes!
duane hall
failed mot
what brake lines do you have and when i had a CBR i went from the brake lever down to each caliper bypassed the splitter altogether .
hi hows it going
CBR_LOVER
Post by CBR_LOVER »
Got a 1995 CBR1000F m8 - we are thinking about de-linking the brakes,not because we don't like the system.....but because it's playing up a bit....
We've bled the brakes in order as the Haynes manual states,and had the front callipers apart for a good clean,but they are still binding.Can't figure it out.
duane hall
failed mot
i have a TL1000R 1998 i had trouble with my front calipers.
Tried to clean them but in the end bought second hand ones . it solved the problem :twisted: that was only because i could not be bothered to buy new seals ,
but it could be your master cylinder what it falls down to is money this not a cheap hobby . ha ha :P
hi hows it going
CBR_LOVER
Post by CBR_LOVER »
Tell me about it m8 - gotta make the best of what we've got at the moment - won't be able to get a ZZR1400 for a couple of years yet... :evil: :wink:
