Chain Cleaning
Dave
Chain Cleaning
Post by Dave »
What do you guys use for cleaning your chains :?: ...
What's good & what's not :?:
What sort of results/problems have you had with different products
Dr Rich
Post by Dr Rich »
The SV dudes swear by parrafin. I use muc off and wd40. I use Castrol Wax after but it flings a bit. That 'dry' stuff is meant to be good. Im hoping this forum will be a refuge form the 'get a scotoiler brigade....'
[img]http://www.southwestbikers.com/images/sigs/drrich.jpg[/img]
Not a girl, rides an SV650S in Candy Ass Blue. Also check out [url]http://www.sv650.org[/url] & the[url=http://forums.sv650.org/viewforum.php?f=19]SouthWestSurfers[/url] SV group
clunk
Post by clunk »
Dr Rich wrote: Im hoping this forum will be a refuge form the 'get a scotoiler brigade....'
:twisted: :twisted:
You can run but you can't hide......
Get a Scotoiler
You know it makes sense :wink:
AquaMan
Post by AquaMan »
With a GPZ I used to own, I would remove the chain and soak it in parrafin
then wipe of the muck and let it dry off for a bit. I had one of those tins of chain lube that you heated up on the cooker to make it fluid, then popped the chain into the tin let it soak for a while before hanging it up to let the excess run off. Then refit.
What a pallaver :( But you knew the stuff had got into the right places.
Now I just use a can of degreaser and a stiff brush to clean it and a can of chain wax (usually Castrol) to lube.
Plus I have to clean all the spattered crap off the rear wheel afterwards :x
It's all a trial of lurve init :D
[size=100][color=green][b]It's Mean n' it's Green[/b][/color][/size]
[img]http://www.aquazero.co.uk/signature.jpg[/img]
Akula
Post by Akula »
Another Paraffin fan here, cleaned mine for the first time 2 days ago with a paint brush and the amount of crap that came off was astounding, let it be for a couple of hours cleaned off the excess and sprayed it with some chain spray that i found in a hardware store.
Regards
Akula
aka Martin
ZX6R
Post by ZX6R »
Get a Scotoiler
Fit a scotoiler, and use chain lube/wax and you should be able to get 30,000 miles from 1 chain. well ok 34247 to be precise!!!!
Nobody with a good car needs to be justified.
Just kwakers
zx6r@southwestbikers.com - Site Moderator
MikeyBEU
Post by MikeyBEU »
Sorry Dr Rich I'm witht he other guys, get a scotoiler!!
I also use parafin (perhaps because my house runs on heating oil and I've got tons of the stuff just sitting there running my Aga!! Cleans it up nice (use a tooth brush) but it does make a mess of the garage floor!
Mike
Blue SV650S K3 Bog Standard (up for Sale)
Black BMW F650GS, Comfy, Sensible and Fun!
Monkey
Location: Bristol (my other vehicle is a tractor, of course)
Post by Monkey »
ZX6R wrote:
Get a Scotoiler
Surely the reason for fitting a Scotoiler is so you don't have to use any other wax/lube :?: :?
Had someone get over 60k out of the chain on an SV:D :D our friend Rictus. Not bloody bad I say! 8)
[color=orange][b]Monkey[/b][/color] :D
[color=red]Please be aware that I may be wrong about anything I write ;)[/color]
[color=olive]The person who risks nothing, does nothing, has nothing, and is nothing. Only a person who risks is free[/color]
