rear brake switch
V6 Mondy
rear brake switch
Post by V6 Mondy »
Following on from our new purchase (RF600), does anyone know why the rear brake light might not work whilst operating the rear brake pedal ? Front brake lever lights it up fine, is there a swich somewhere or any other reason it might not work ?
Thanks
Steve
Yes, there is a separate switch for the rear pedal.
look around the pedal area and you should find a spring leading off the pedal somewhere to a switch unit :D
little nick
Post by little nick »
very common for the rear switch to be full of crud & rust = not working
WD40 is your friend
jason
Post by jason »
yeh probably just crud infested through age but it could also be that its not even there anymore.
has it got standard footpegs?
The switch might just have been removed, I always chuck my rear light switch assembly in the bin when I change rearsets. (or maybe its just me that does that)
Rab
Post by Rab »
you could change the switch to a banjo switch then no chance of crud stopping it working
Ive changed my rear and front to banjo switches
V6 Mondy
Post by V6 Mondy »
I think i might have to have a look at the weekend now, since it's dark at like 3pm now :?
Whats a Banjo switch ? And yes it has standard footpegs
thanks so far :wink:
little nick
V6 Mondy wrote:I think i might have to have a look at the weekend now, since it's dark at like 3pm now :?
It's a banjo bolt with a pressure activated switch in it. It replaces the standard brake banjo bolt at the master cylinder. If you fit this - you can remove the standard brake switch - worth it on the rear to avoid the rust / crud problem, almost essential if you fit rear sets.
take the rearset off and give the switch a clean using a toothbrush,
as above, get the wd40 on it and manipulate it by hand until the light begins to work, if that doesnt fix it make sure u dont have a break in the wire.
Mike Daytona600
Post by Mike Daytona600 »
The normal switches are adjustable so you might just need to wind it up a little. Mine kept needing adjusting but was a pain to get to so I put a banjo switch on, more reliable :D
Parker's
Valeting
Service
Tel: 07751883056
V6 Mondy
Post by V6 Mondy »
right, found the switch and looks like the previuos owner fitted a square ended switch into a round holder :? It works (just) but still require a new one as there's no adjustment as thats missing too.
