Ground Anchor
GixerSi
Ground Anchor
I just bought a mammoth ground anchor from the bike shop, got it home to discover the instuction guide is missing! I know its not rocket science but i'd rather do it right. Any ideas anyone? Otherwise its a trip back to the bike shop next week......
Re: Ground Anchor
im guessing it came with the expansion bolts etc?...
GixerSi
Re: Ground Anchor
Yes it got bolts and ball bearings in the pack. You got one?TOM91 wrote:im guessing it came with the expansion bolts etc?...
- delvey91
- First Name: JACK
Re: Ground Anchor
Get a decent sds drill or similar, Put the ground anchor where you want to put, mark the holes. Use a drill bit slightly larger than the rawl bolts and drill the holes. Then bolt it down
2011 Yamaha WR450F
2004 CCM 404DS
2004 CCM 404DS
GixerSi
Re: Ground Anchor
Cheers Delvey, i'll have a go next week.....delvey91 wrote:Get a decent sds drill or similar, Put the ground anchor where you want to put, mark the holes. Use a drill bit slightly larger than the rawl bolts and drill the holes. Then bolt it down
Re: Ground Anchor
and then smack the ball bearings into the bolt headsdelvey91 wrote:Get a decent sds drill or similar, Put the ground anchor where you want to put, mark the holes. Use a drill bit slightly larger than the rawl bolts and drill the holes. Then bolt it down
- Sir SUKI
Re: Ground Anchor
GSXRSi will have had to pull a favour in to fit this one. He is useless at anything DIY. Out of interest, anyone seen his ground anchor in position? LOL He'll probably ask me to do it in the Summer.
