2 Stroke crank case sealant?
I need sealant for the two halfs of a crank case. I've got some 'instant gasket' cr@p from halfords that i've used on a sumps before an other low pressure/temperature areas don't wanna use that. I've read a bit about 'yamabond #4' and silicon type RTV sealant?, need something that will hold good pressure and won't leave me with oil p!ssing out everywhere and a 2 stroke that wont run properly! :lol: What are people's sudggestions and what have people used before? Ideally I need to pick some up at the weekend dont wanna be waiting weeks for some to turn up through ebay or whatever
cheers, tom. :)
SteveR3
First Name: Steve
Re: 2 Stroke crank case sealant?
Post by SteveR3 »
This is the one I use - Blue Hylomar applied to both sides of gasket.
http://www.hylomar.co.uk/
Steve.E
SteveR3 wrote:This is the one I use - Blue Hylomar applied to both sides of gasket.
awesome thanks bud i'll have a look, althought the engine doesn't have a gasket for the two halves.. this stuff is the gasket :shock: Which is why i'm gonna do it with the proper stuff!
wurth silicon rtv is the stuff you want. different types available to suit all needs
jam
Post by jam »
As stated in my pm, use either Wellseal or Threebond from Yamaha, both are designed exclusively for sealing flanges where there are no gaskets used, I use them to seal crankcase halves, the Wellseal seems to be better but Threebond may be easier to get hold of.
jam wrote:As stated in my pm, use either Wellseal or Threebond from Yamaha, both are designed exclusively for sealing flanges where there are no gaskets used, I use them to seal crankcase halves, the Wellseal seems to be better but Threebond may be easier to get hold of.
haven't recieved a pm jam, :| I got some Wurth RTV today, havent used it yet but it seems exactly what I need will try it at the weekend thanks guys
