All set and ready to go to Donnington for Tuesday. Am traveling up tomorrow morning so I can see some friends and family (including getting a set of scrubs + a dyno run).
Ysterday it looked like it could be wet, but now its saying dry? Either way should be a tropical 14 degrees so should be good. Ended up having to swap the 600 engine out as it had some running issues (had a spare 750 in the garage). Was a bit of a pain but well worth it on the test ride, smooth and good power now rather than...........no power and ummm not smooth
Stripped and cleaned the front brakes (in the dishwasher again), gave the pistons a polish and it is a night and day difference over what they were before. On the other bike I changed m/c and calipers twice, this was a much cheaer and potentially better solution (that will be seen shortly when the project is finally finished), if I knew what I now know.......
This is how she stands
Bargain £5.50 ebay front fairing I picked up a year ago or so, looks, well, shite but is strong and does the job
Will spray with some black paint at some point, but not top of the list at the mo!
