New Odometer
thebish
New Odometer
Post by thebish » Nov 20th, '18, 15:57
The speedo unit on my Er5 recently stopped working (it wasn't either of the cheap options - the cable or the servo) - so I had to source a set of clocks from a breakers yard. I fitted them (swapped over the casings cos mine were better) - but essentially installed the complete unit as is - and they work fine (speedo-speed matches sat-nav speed near-enough!)
My question is about the odometer. The odometer on the new set reads about 13,000 miles fewer than my original set.
What do I need to do about this? Is it a problem I need to address, or is it just an issue where I need to show documentation (photos?) and provide full disclosure if/when I sell it - or will this be a problem at any other time - eg. MOT?
I'd appreciate some guidance! :-@
Re: New Odometer
Post by billinom8s » Nov 20th, '18, 16:27
mot records will show the genuine mileage but personally i would have made a note of the current figure and mae a note in my records.
where i used to work we had to replace whole speedo units fairly often and had a sticker made up that would get put on the back of the new one to say the engine mileage and the date of the new speedo unit.
Zx10r trackbike, WR250
menzies3032
First Name: Robert
Re: New Odometer
Post by menzies3032 » Nov 20th, '18, 16:29
The interesting bit is I don’t think there is any law governing it. However your MOTs record the previous 5 years mileage so going to be obvious it has gone backwards so suggest you keep everything for when you come to sell it so the new owner knows it’s done due to all of the correct intentions.
Living in Teignmouth, Riding a Suzuki GSXR 1000 K7
Follow me on YouTube - https://www.youtube.com/channel/UCDMdBs ... TR70_NBKjA
Jug_Inspector
First Name: Richard
Re: New Odometer
Post by Jug_Inspector » Nov 20th, '18, 17:16
I'd just make a note of the date & mileage that it was changed at and record that in the service book or somewhere.
I wouldn't bother getting the new speedo updated to reflect the real mileage.
Just keep as much proof as possible for when you come to sell.
There won't be any issue at MOT time.
thebish
Re: New Odometer
Post by thebish » Nov 20th, '18, 17:30
thanks to you all! :-bd
bkingalan
First Name: Alan
Re: New Odometer
Post by bkingalan » Nov 20th, '18, 19:42
Replaced the one in my focus nobody asked any questions at mot test and that was 5 years ago 👍👍👍👍
1290 SD. Gsxr 1100 streetfighter. GSX 1400. 1200 bandit.
MikeZ
First Name: Mike
Re: New Odometer
Post by MikeZ » Nov 21st, '18, 00:00
I had to replace the speedo on my xj600. When i look on vehicle smart the mot mileage is recorded back to 2006 (info from dvla or whichever govt dept keeps the records) it is obvious and highlighted as a discrepancy but not an issue. No need to do anything.
thebish
Re: New Odometer
Post by thebish » Nov 21st, '18, 09:43
thanks! :D
Smiler
Rideout Ringleader
Re: New Odometer
Post by Smiler » Nov 24th, '18, 08:58
'Updating a speedo'....I'm fairly sure that bit IS illegal (tampering with odometer?) and I'd be interested to know the legal implications from the MOT history POV too...? ie, do you HAVE to provide evidence that its been changed?
Jug_Inspector
First Name: Richard
Re: New Odometer
Post by Jug_Inspector » Nov 24th, '18, 10:14
Do have any links to any info this is the case?
Tampering in the legal sense does not simply mean adjusting it. If you reduce the mileage to make a gain on the sale then that is fraud.
If you have the odo adjusted to reflect the real mileage you are complying with the law.
If you don't have it adjusted but declare the mileage not to be correct you are also complying with the law.
MOT mileage history;
On the history for my DRZ it gains steady over the years and suddenly drops back to 250 miles. Reason for this is I changed to speedo for a digital one (with correct mileage) and the tester miss read it. So that trimmed 11,000 miles off and nothing was said.
MOT doesn't care about mileage, it just gets recorded.
