New guy plymouth ecu-tuning
Re: New guy plymouth ecu-tuning
Hilltop has been going for years and MJTuning seems busy
I don't get the Teapot reference either but I think this is the video of the GSXR1000 having the treatment.
The comment section looks a bit lively but nice to see Goeff chiming in occasionally to defend his company.
I was sceptical too but the feedback on the KTM forum was generally positive so I gave it go, and I'm pleased with the outcome.
https://www.youtube.com/watch?v=zT2t2mtecUY
Thanks for that! Explains a bit more about how it works - seems to be basically power commander-esque software on a (no doubt hidden) partition within the ecu. Interesting to note the comments about the bike running lean, but still doesn't explain how it "self learns" without using an O2 sensorJug_Inspector wrote: ↑Feb 20th, '19, 09:46I don't get the Teapot reference either but I think this is the video of the GSXR1000 having the treatment.
Edit - the '17 Gixxer does have an O2 sensor, which probably explains the self learn - does the katoom, Jug?
Further Edit - just read the comments section on YouTube. Interesting. I'm no computer expert, so can't say what is/isn't bullsh** ..... But some are clearly rather mean as most owners seem happy with the result, which is what matters. And let's face it, if you want a successful business, you've got to be a salesman too, haven't you
Yes, it has one for each cylinder.
From chatting to Goeff I think the program is not so much self-learning, well not as I would think a self learning system would work. There is no teaching process or period of riding for it to learn. It just overrides the stock map it seems. It takes inputs from the bike and then decides what the fuelling should be, maybe this system has some self adjusting capability, I certainly hope it does.
The stock Lambda sensors are still used but not for sensing O2 levels. Goeff explained that he uses them to sense EGT.
I was very sceptical when I heard this but after a little googling on how narrow band O2 sensors work I could see that sure enough, when at low AF ratios their voltage output is constantly high but does change as they get hotter, so they could be used to keep and eye on EGT, but I'm not sure how accurate it would be.
I suppose that if the program ever does accidentally lean the mixture too much the sensors output will snap low and the program will know instantly it's just screwed up, so by leaving the sensors in there you still have protection against over lean running, that is if the software is programmed to react to that.
apparently 'teapot' is a person, he's a blogger from Performance Bike magazine.
MJTuning wrote: ↑Feb 19th, '19, 23:17The A/F ratios adjust automatically with the programme that we put into the empty space. Think of it as a powercomander built into your ecu with a auto tune set up. As for lamber sensors no bike runs wide band sensors which are the only ones that can check A/F ratios most modern bikes only have narrow band sensors which only check for carbon in the exhaust. Go to the website www.hilltopmotorcycles.co.uk and this might give you more of an idea as to what we do.TLS-Moose wrote: ↑Feb 19th, '19, 17:02Hmm ...... Re-maps without a Dyno? How do you check a/f ratios (given neither of mine run lambda sensors)? I thought "remapping by post" was the preserve of diesels, which can't run lean .....MJTuning wrote: ↑Feb 19th, '19, 13:46 Thanks for the query we can get into most ECUs for fuel injected motorcycles as long as I have a plug which will get me into the obd port. If I can’t access it I can put you in touch with HQ and they can definitely flash your ecu by accessing directly. You would just need to go there or send your ecu to them. Unfortunately on the dyno side there isn’t one we currently have down here but we only use dynos for power print outs we don’t need synod for the set ups as the program is automatically tuning on the fly so is much more advanced than just a set op on a dyno. But again if a power print out is what you want I can put ou I touch with HQ and they can arrange a dyno day with you
Cool well that answered some of my questions to be fair.
So in essence it is a flash on the ecu to get it to run closer to optimum levels rather than the safe levels that the manufacturer states.
I can see this being useful for some vehicles with an aftermarket system fitted as can adjust the feeling to suit without a full map,
Unfortunately (for me at least) I wouldn't let anyone map/setup a petrol engine if they are not listening for detonation.
chr1s
- First Name: Chris
Teapotone went round the world on a gixxer 1000, has a growing YouTube channel, organises small bike tours with a difference, and is an all round top fella. He doesn’t work for PB though, Si.
I went away to the Picos last year with him and 3 other lads and he made 3 videos of it. His editing skills are awesome but I know zilch about that stuff. He has plenty of other vids on there too.
https://youtu.be/5gBWVR7IdUg
As for Hilltop and his services, I know little except Bruce (teapotone) took his GS there and is very happy.....My thoughts on the matter are the same as TLS-Moose... ;)
- Guest user
I'm still old school - experienced dyno operator with a wide band lambda up the bikes poop chute to set the AFR, and if needed optimise the timing has always worked for me to get the best out of each individual bike.
1960 BSA A10
1960 BSA A10
- Jay
- First Name: Jay
Hello and welcome to the site.
Out of interest...... what would the cost be to flash and set up a 2011 blade?
Bullet
Had mine mapped by woolwich, he didnt have to touch in the end as its already race mapped by kawasaki it turned out so it mapped one of the other power modes to give me an option of 2 high power modes
He doesnt ise dyno either as everthing he needs is on the ecu and only does dyno if customer wants a print out
- Jay
- First Name: Jay
Defo wanna get my ECU mapped .... hopefully he will see this?Bullet wrote: ↑Feb 28th, '19, 00:07 Had mine mapped by woolwich, he didnt have to touch in the end as its already race mapped by kawasaki it turned out so it mapped one of the other power modes to give me an option of 2 high power modes
Message Si, I believe he has his contact details.
- Jay
- First Name: Jay
Thanks Moose
