Fao ruffian
julesh
First Name: julian
Fao ruffian
Post by julesh »
Been and gone and made a mess of my subframe by overtightening a nutsert, as far as I'm aware it's magnesium (2014 R6) what's my best option here please?
Re: Fao ruffian
Chances are it's a magnesium alloy in cast.
Got a chance at welding it up, or if its past a structural point then it wont really matter.
The other thing would be to clamp it tight and put a brace alongside it drilled and bolted alongside.
Options are there and depends on where it is on the subframe etc. Wider pictures could help.
Or the other option of a second hand subframe.
Dan_RR
First Name: Dan
Re: Fao ruffian
Post by Dan_RR »
If the plastic rear fairing covers it up then you could just use a smaller nut and bolt with a couple of washers as I'm guessing the insert is spinning now? Obviously that's if Ruffian doesn't sort you out with the old glue gun :)):
Link to all my drifting shenanigans, motorbike track days and a few 'how to's....
https://www.youtube.com/channel/UCfKNYG ... REP05rR1bA
julesh
First Name: julian
Re: Fao ruffian
Post by julesh »
the nutsert is in TIGHT, I was hoping to drill it out,weld or repair the crack,then reinsert a new nutsert, "gently" the sert is for my seat unit so it'll come under a lot of movement from me shifting around in the seat
julesh
First Name: julian
Re: Fao ruffian
Post by julesh »
ill post up some better pics as soon as i can, at the moment this website wont allow me ????
julesh
First Name: julian
Re: Fao ruffian
Post by julesh »
http://www.trackdayriders.co.uk/tdr/for ... 75848.html
Haven't been able to upload anything on here for two days 🤔🤔 link for you Ruffian with a wider view
Re: Fao ruffian
Hindsight is a wonderful thing and should have used an alloy nutsert.
Personally as I have the gear I would pull the subframe. Clean it up and well the crack and the nutsert area to thicken that mount then just drill and tap the fresh alloy weld.
