Thought I'd kick off a topic to raise awareness of SWB's very own billinom8s (aka Simon) and his expertise in the motorcycle suspension department.
Recently I had occasion to pick up the phone and ask Simon a question re' my Triumph Sprint ST front fork legs and the servicing thereof. I'd done a bit in this department myself but it was in the dim and distant, when Noah was a lad. That was when you drained the old oil out of each leg via the suppled drain plug, pumped the suspension up and down a few times and threw in whatever oil you happened to have lying around. Things have moved on a bit from then.
So, after being convinced I should do things properly for a change, and being invited to Rolls Towers to do so, I and aforesaid fork legs plus a pair of almost new OE springs (only 18,000 miles on 'em - new by my standards, and more importantly, free! ) duly reported for training.
As most of you know, Simon is a tad crook after having the sawbones operate on his right shoulder; so, he supplied the brainpower, tools and coffee and I followed orders. What would have taken Si' about an hour I managed to stretch to about 3 1/2. He was still speaking to me at the end so all good .
In a nutshell, and if you've cut to the chase to look for sordid details, the old fork oil was bleedin' 'orrible! It looked and smelled like something that had leaked from a septic tank and the sludge in the bottom of each leg was as thick as syrup; I took a couple of pic's of that which I'll put up later. My Sprint has over 68,000 miles on it and I doubt the oil had been changed for years. Once cleaned out, and that took some doing due to the sludge, some nice new Motul SAE 10w medium weight oil went in and the air gap set to 120 mm. Simon has a natty device for getting this essential measurement absolutely accurate. Some minor spanner twirling to rebuild the fork legs and a bit more natter and banter later and we were done.
After re-installing the legs on my bike I've only managed to get about 15 miles under the wheels so far so can't give a definitive take on the result yet. That short ride felt good though, immediately smoother and more compliant being the first impression. I'm off on one of Brian's marathon rideouts tomorrow (19th March) and will definitely know more by the end of that.
billinom8s - suspension guru.
- Robbo87
- First Name: Phil
Triumph Sprint ST 1050.
- Robbo87
- First Name: Phil
Re: billinom8s - suspension guru.
Here's what the sludge and some of the old oil looked like when we removed the fork cartridges:
Guru did the fork valves and springs, also done a general service. Happy customer!
BMW F900GS Adventure
Honda CBR 929 - old but gold
KTM 350EXC - needs a wash
- First Name: Colin
Simon I'll be giving you ring sometime soon for a suspension setup
Now riding a Tuono V4 1100 😀
Not a problem.
- First Name: Darren
Looks awful that I bet your forks will feel much better.
1290GT / Gixxer Thou K6 the best one.
- Jay
- First Name: Jay
Highly recommended, Si did my old 2011 blade with K-Tech internals and rear shock..... Amazing.
Also he set up my RR-R and OMG what a difference..... Cheapest and best mod you can do to your bike.
2020 CBR1000RR-R
2008 FJR 1300A
2008 FJR 1300A
