Deposit down! ZXR400 :)
Johnnyb
Re: Deposit down! ZXR400 :)
Post by Johnnyb »
Or three bikes dented in identical places, maybe its a design fault in that bike............... :wink:
Johnnyb wrote:Or three bikes dented in identical places, maybe its a design fault in that bike............... :wink:
shhh! it's not! :lol:
Do any of your mates have a Full driving license, if so borrow a van ( or hire if they are old enough) and go get it!
badgerKDD wrote:Do any of your mates have a Full driving license, if so borrow a van ( or hire if they are old enough) and go get it!
yehh.. 'delvey91' has a van and has kindly offered.. and also two of me mate's dad's have vans that i could borrow for the day so pretty sorted :)
On most "fabricated" ally frames, a dent or scrape on the side of the beam isn't the end of the world ....... you don't throw a car away just got it has a dent in the wing, do you :roll:
Depending on the depth of the dent/scar, you can weld a little tab in the centre of the impact and pull it out a bit with a slide hammer, then fill whats left with ally weld and grind and polish or paint so it's invisible 8) Done this a couple of times with no problems at all :D
If the dent/crease is up around the headstock, it's a different story, and you have to play very carefull ..... some bikes (R1's) are notoriously weak in this area ......
Another thing to watch on ally frames with frontal impacts, especially on bikes with USD forks, is that the steering bearing seats (and fork legs around the seals) can become ovalled, and it'll always cause problems thereafter .... :evil:
BladeMan
First Name: Mark
Post by BladeMan »
Nice bike M8 i had one about 10 years ago. I hope to get another one day.:)
Stately
Post by Stately »
Check out the way the fairing panel is way off in the 6th photo.
It's not even close to mating up with the upper fairing.
I'd want that panel off and have a good look underneath at the mounting points.
That's the only trouble with fairings.
They can hide a multitude of sins.
Varcon
First Name: Edd
Post by Varcon »
Funky..im not sure if the frame is bent...just looks like the lighting ?
Nice bike mate, will look good with a bit of money spent on it, ideal timing for the summer ! Was gonna say give me a bell when you pick it up and ill ride down with you as trowbridge is very close...but as your not riding it that might be hard !
