Looking for a fabricator/welder/paint sprayer
- First Name: Wayne
Hi all,
I am looking for someone who can fab my rear fender on a yam 1700 warrior i need about 2" cutting out of the middle then welding back together will explain over the phone...lol
Also looking at paint job over winter ....tank , front & rear fenders and 2 side panels. Also
Does anyone know a reasonable chrome plating place as i cant believe the price some places are charging like £25 just for a brake or clutch leaver
Anyway guys let me know.
cheers Wayne.
cheers Wayne.
By Order of the Peaky Blinders
Re: Looking for a fabricator/welder/paint sprayer
Are you meaning something like this??
Welder fabricator I may know a guy
As for painting dunno anyone at the moment.
For chroming how about going to a chrome powder coat anyways? Will last well outside and probably a lot cheaper
Where abouts are you? Or a photo of the mud guard may help.
I do a lot of welding/fabricating at the garage I work at. If you sent me some pics of exactly what you want and as long as it's mild steel I can probably help. Send me a message if your interested.
Cheers Dan
Cheers Dan
Link to all my drifting shenanigans, motorbike track days and a few 'how to's....
https://www.youtube.com/channel/UCfKNYG ... REP05rR1bA
- First Name: Wayne
Hi Dan
I am in Honiton, yeah its mild steel and quite heavy gauge as its a cruiser i want more of the back showing the trouble is the rear light fits into the rear fender...
so i need the tail section so most owners of the yam Warrior have around 2" cut out the centre then welded back together i will be having it sprayed over winter so its a job for later just need to make some connections i will send u pickies when i get 5 mins mate. best if we can hook up so you can see it.
If you look at the photos above that was a 6inch section cut out and removed from a triumph bobber rear mud guard. Tig welded butt joint and sectioned to get the edges lined up due to there being a slight flair on it.
- First Name: Wayne
Hi yes thats the sort of thing i am looking at and it has to be linished off and ready for primer,
where abouts are you?
Like i said you will need to see it for yourself then wel go from there bud
cheers wayne.
cheers wayne.
I'm willand but always floating around.
I know it will be linished off and then primed and painted.
Like this job above was on a 12month of triumph bobber. And done so people didnt know it wasnt factory.
Being an ex panel beater and mechanic always helps.
Now do dairy food stainless steel welding (hygiene)
Plus the nice thing with tig is can minimise heat input and distortion.
This is some of the alloy I have done
- Tractorwackyracer
- First Name: mark
- First Name: Wayne
Hi mate yes thats the sort of thing i am looking at will be intouch bud when ready just need to find a paint sprayer now
cheers Wayne
cheers Wayne
What colour is it going??
Ah ye nice TIG weld there, looks like you found your man with Ruffian, let me know if anything changes. Cheers
Cheers Dan. I do try and take pride in the tig work. Especially the welding and fabrication side of things.
Last year did a pie cut exhaust for a low level speed triple exhaust as the link pipes were not available for that specific can. And that was a good laugh.
I have some intercooler pipes to do on my subaru and been pushing the alloy work of late to improve and get to a standard where I am happy. Getting closer now and just feel i need to organise my work station a bit better for the next steps.
Also planning on making some crazy bits and pieces of the zzr600 build in my head. Like custom alloy tubular subframe and panelled infill.
- goatpants
- First Name: Chris
Nice bit of weld thatRuffian wrote: ↑Aug 3rd, '20, 12:21 I'm willand but always floating around.
Brummie if you do want me to come and have a look see I am more than happy most evenings etc.
Just send me a message and can arrange a date.
- First Name: Wayne
Ok mate will do
Will give you a shout when i know exactly what i need
cheers
cheers
