why oh why???
why oh why???
There was me thinking that a washer could do the job fine, when really it needed to be welded!
Re: why oh why???
Is it just the nut & washer that's welded?
Fingers crossed it is just that...
Re: why oh why???
Beats using thread lock
Re: why oh why???
Interesting for a front sprocket nut.
Should be able to dremel and cut the welds and remove.
Re: why oh why???
That's the plan.
Re: why oh why???
Provided they havent done that because the spines or threads are damaged.
But hopefully not
But hopefully not
Re: why oh why???
I'm sure that was a fairly common thing to find on 1st Gen Africa Twins
KTM 1190ADV - sold
KTM 790ADV - sold
KTM 790 Duke - current
Honda CB300R - can I get any smaller
KTM 790ADV - sold
Re: why oh why???
That does seem like a lot of weld if it's just so the nut holds on to that washer..
Any chance it's not actually weld but something like chemical metal (JB weld)?
Re: why oh why???
hoping it's JB, heavy handed DRZ owner.
the dremel will come out first, followed by the grinder!
Re: why oh why???
A pic from a transalp on the africa twin forum
Re: why oh why???
DRZ.. it'll likely be JB weld.
DRZ's need loctite on the splines to stop that nut coming loose.
Mine ate that washer a few times before I started putting Loctite 270 on the splines.
