Electrical fault need help
- First Name: Darren
Hi my Gixxer K6 Thou has a short when I turn the bars with right indicator running. Only when I turn it left. Ive traced the wiring to the right indicator so the green wire power side runs from the indicator to the main harness behind the right fairing then to the fuse box.
The harness moves when the bars turn left Im wondering if the plastic connector has deterioriator so the wires in it are touching.
Can anyone provide tips how to test never shorts when right indicator removed.
I thought perhaps remove fuse earth multimeter then place positive probe load side of fuse and move wiring till I get continuity to test for a short?
GEN 4 S1000RR / Gixxer Thou K6 the best one.
Re: Electrical fault need help
I had something similar a few years ago. Every time I used the back brake. The indicators and the horn failed.
One of our locals ran a used car business and he had a look. He found a miniscule rubbiing of the front brake wire which was bare (about 1 mm ) and touching the handlebar. A tiny bit of tape sorted it.
I would say buy a KTM Darren but considering mines just had a full rewire perhaps I won't
MV 1000 brutale rs
MV 800 turismo veloce luso
P.S.
I bought a bag of 50 fuses of the net at a silly (cheap) price. Whenever it happened I just lifted the seat and banged in a new fuse.
Thx Guys Alan I doubt a KTM's a good idea lol a bag of fuses good idea but the fuse box is behind the right fairing so gotta find the short
Undeniable the indicator and see if it still does it. If it doesn't then you know the fault is in the indicator unit.
Yeah cheers Si gomna have a good look this Saturday as I need the bike working for track soo
Sounds like a good plan.
Could also try to isolate those wires, like if they run to a connector then unplug that and test each wire to earth whilst moving the bars.
I trust you've given that loom a good visual inspection?
Sometimes you have cut away the whole sleeve so that you can inspect each wire separately as a couple of them could be chaffed and be shorting together in that loom.
I'm surprised Simon hasn't observed that as it's a Gixxer being stopped might avoid a bike/hedge interface
- Jay
- First Name: Jay
Must be the connection for the hair straightenersBilko1000 wrote: ↑Mar 2nd, '22, 19:52 Hi my Gixxer K6 Thou has a short when I turn the bars with right indicator running. Only when I turn it left. Ive traced the wiring to the right indicator so the green wire power side runs from the indicator to the main harness behind the right fairing then to the fuse box.
2020 CBR1000RR-R
2008 FJR 1300A
2008 FJR 1300A
At least he has hair
- Jay
- First Name: Jay
2020 CBR1000RR-R
2008 FJR 1300A
2008 FJR 1300A
Seems to me you might need some insights from "Ruffian". Always found he is some kind of electrical wizard, pretty handy with a welding machine as well
Hey guys the 10amp fuse blew again today.
Could it be the LED license plate lamp fitted they used to be 12 bulb just wondering as ive read you should fit a resistor when replacing bulbs with led just a thought?
No, it won't be that.
LED products have resistors in them to limit the current and stop them from blowing.
You only need to add resistors when replacing standard indicator bulbs with LED's, and only then if you have an old tech indicator relay.
Your problem is in the wiring I think.
