Hi all, I had a quick question as i was unable to find an answer.
If I bought a private number plate that's 3 digits, would it be 2 on top 1 on bottom or would all 3 o top be legal? Gov website states a minimum of two lines is required so was confused on this matter. And if its 5 digits, is it 4 on top 1 bottom or 3/2 etc I was a bit confused.
3 or 4 Digit Number Plates
- First Name: Nico
Re: 3 or 4 Digit Number Plates
Hi Nico, saw the same question on another site the conclusion then was 2 lines , 2 on top or 1 would depend on the letters/numbers you have.
MV 1000 brutale rs
MV 800 turismo veloce luso
All depends on layout,
If its prefix or suffix aged plate
(As to where the space should be between the number and letters)
I have a 5 digit plate which should be on 2,
Used to run it on 1 though and didn't attract any attention as the letters where the right sizing +margins.
