Hi guys,
Im in a little bit of trouble. My rear brake pin that holds the pads in place is just not moving. does any one have a good idea what I will need to do.
In failing no help its looks like I am going to have to find another caliper to buy and replace the whole unit.
if any one is in the swindon area too and have the skills to remove that too would be spot on.
cheers
CBR900 Seized Rear brake pin
[img]http://i58.photobucket.com/albums/g248/garvey2003/carbon300.gif[/img]
have you taken the cap off yet or is that the bit your struggling with?
i had exactly the same trouble with my blade, had to drill the cap off then undo the allen key pin, and didnt bother putting the cap back on. if its the allen pin , then just let some wd40 or something like it, to soak in over night, then have another go.
RAWRacing.co.uk
RAWRacing.co.uk
I have unscrewed what i could call a cap. its about 1/2cm and screws in. thats out no worrries. but It doesnt look like an allen key top inside. just a hole with threads.
Im going to give it another shot tomorrow night after work
