When I bought the bike it came with no history apart from the MOT certificate and a couple other things. (showing 18000 miles/ish) Today I was sorting out the insulation around the wires whilst the front was off and I started to notice a few things..
-Around the Speedo clock is filled with polyfiller and painted black.. (The revs and temp clocks have a proper rubber seal round them)
-Their are small nuts and washers missing underneath the speedo which fix it to the bracket.
-Theirs dirt on the inside of the speedo (so it's been opened, or not sealed up properly) and the numbers on the mileometer don't quite line up properly (although it's not really obvious).
-The day I got the bike, the speedo cable un-screwed from the back off the speedo whilst out riding home with it. Which gives me the impression it was probably only done up by hand?.. So probably left disconnected by the previouse owner whilst he was using it?..
So, from this I think it's pretty obvious that it's been fiddled with.. but what can i do about this? If anything? Obviously there's no telling how far the bike's been now. And.. I thought tampering with mileage was totally illegal!
I guess I should have checked it out more when I went to look at it. But I aint gonna dwell on that now.. The bike seems to run nice and is def worth what I paid for
One other thing which kinda ties in with this.. how often should timing chains be replaced? Isn't it around 35K? Or does it vary dependant on the bike and how you ride it? Thanks!, Tom.
