2 Stroke crank case sealant?
Posted: Jul 29th, '10, 20:08
by Milky
I need sealant for the two halfs of a crank case. I've got some 'instant gasket' cr@p from halfords that i've used on a sumps before an other low pressure/temperature areas don't wanna use that. I've read a bit about 'yamabond #4' and silicon type RTV sealant?, need something that will hold good pressure and won't leave me with oil p!ssing out everywhere and a 2 stroke that wont run properly!
What are people's sudggestions and what have people used before? Ideally I need to pick some up at the weekend dont wanna be waiting weeks for some to turn up through ebay or whatever
cheers, tom.
Re: 2 Stroke crank case sealant?
Posted: Jul 29th, '10, 21:48
by SteveR3
This is the one I use - Blue Hylomar applied to both sides of gasket.
http://www.hylomar.co.uk/
Posted: Jul 29th, '10, 21:56
by Milky
awesome thanks bud i'll have a look, althought the engine doesn't have a gasket for the two halves.. this stuff is the gasket
Which is why i'm gonna do it with the proper stuff!
Posted: Jul 30th, '10, 07:35
by deej
wurth silicon rtv is the stuff you want. different types available to suit all needs
Posted: Jul 30th, '10, 12:44
by jam
As stated in my pm, use either Wellseal or Threebond from Yamaha, both are designed exclusively for sealing flanges where there are no gaskets used, I use them to seal crankcase halves, the Wellseal seems to be better but Threebond may be easier to get hold of.
Posted: Jul 30th, '10, 16:38
by Milky
jam wrote:As stated in my pm, use either Wellseal or Threebond from Yamaha, both are designed exclusively for sealing flanges where there are no gaskets used, I use them to seal crankcase halves, the Wellseal seems to be better but Threebond may be easier to get hold of.
haven't recieved a pm jam,
I got some Wurth RTV today, havent used it yet but it seems exactly what I need will try it at the weekend thanks guys
