12v computer fans
skippy
12v computer fans
Post by skippy »
Dont ditch those old desk top computers........the main 12v cooling fan works on overheating regulators..........this is my 3rd one and now my last........ :-bd
goatpants
First Name: Chris
Re: 12v computer fans
Post by goatpants »
Nice tip skip
I love that little idea. Can you show us how you wired it in?
skippy
Post by skippy »
Because they are very low amp rated, typically 0.15 to 0.25 amp, they can pretty much be wired to anything that is live when you switch ign on and also when its running........note: [some components have 2 live feeds 1 when ign on and 1 when running....i.e. one of the feeds is not live as soon as the engine starts].
Most bikes have live feed to starter motor solenoid when ign switched on and stays live when running, thats where mine is wired to.
Before fitted after a run you could not touch the reg it was so hot, now its just warm to touch.....no more 60 quid regs for this bike.... :D
Its mostly old bikes that suffer with this!.....what bike you got?
goatpants
First Name: Chris
Post by goatpants »
The fans themselves are only a few squids new :-bd
sckudder
Post by sckudder »
i was thinking of doing this to my R/R as i have gone through 3 of them so far but the last seems to be doing ok for the min. I was wondering what you class as a old bike mine is a k7 gsxr 750 and they all suffer very bad with the R/R
skippy
Post by skippy »
sckudder wrote:i was thinking of doing this to my R/R as i have gone through 3 of them so far but the last seems to be doing ok for the min. I was wondering what you class as a old bike mine is a k7 gsxr 750 and they all suffer very bad with the R/R
1980,s........early 90,s.......
skippy
Post by skippy »
Position of unit i think makes a difference.........mine is under the seat and although it is finned it just does not get the air flow, but it does now............ :mrgreen: :mrgreen:
sckudder
Post by sckudder »
mine is behind the radiator above the manifold not a very good place
R1dian
First Name: dan
Post by R1dian »
what about fusing ??? im thinking of the cold and wet weather getting into the fan
randysway
First Name: Randy
Post by randysway »
Well it looks like it's definitely exposed to the water and elements. I'm assuming that the fan will continue to work after a little splash of rain but don't plan on leaving it exposed in the elements and last long..
Stikley
First Name: Nik
Post by Stikley »
Cut away se of the wire and put in an in line fuse if worried, only a couple of quid, long run much cheaper and less hassle than swapping reg/rects. Used to change mine once a year on the VFR400. Great idea Skippy
1994 Kawasaki ZX9R
2002 Aprilia RSVR
2002 Triumph Daytona 955i
2002 Suzuki AN400 BurgerVan
2005 Kawasaki KXF250
2011 Citreon Relay LWB
Oldskool bikes rule!
