Dash Problems
Mini_Beth
Dash Problems
The other day I went out on my bike. I accidently stalled it as I was pulling onto my drive and when I started it back up again my Dash started flashing and the rev needle was just all over the place.
I took it out a few days later and it was working fine until 20mins into the ride and the same thing happened again.
Nick (my other half) checked the connections to the dash and they are all fine. But when he went to start it the battery was dead. So we charged it up turned the key and the dash was still flashing.
Its a 2010 600 Hornet.
Does anyone have any ideas?? Thanks
- AndyG
- First Name: Andy
- Location: Exeter...................... Rides a Speed Triple
Re: Dash Problems
I could be wrong but when we have this kind of problem with our cars (MG ZT V8) we disconnect the battery for a couple of hours. This resets the computer/ECU.
Maybe this is not relative to your bike but worth a try.
Triumph Speed Triple
MG ZTT 260 Supercharged
MGF Road Race Modified
cobrabuilder
- First Name: Darren
Re: Dash Problems
Probably rectifier or something on the charging system
Re: Dash Problems
I know it sounds simple but have u checked battery connections are tight had the same problem with my sv a few years ago speedo and rev counter were all over the place
Re: Dash Problems
I had the same problem with a vw passat a couple of years ago and as suggested it was the battery connections. They were connected and tight but they had corroded over time. A scrub with something abrasive and away you go.
Re: Dash Problems
If that is the case smear a little vaseline over the terminals when they are clean , it will help slow the corrosion down a lotmenzies3032 wrote:I had the same problem with a vw passat a couple of years ago and as suggested it was the battery connections. They were connected and tight but they had corroded over time. A scrub with something abrasive and away you go.
- AndyG
- First Name: Andy
Re: Dash Problems
Yes Vaseline or Grease.
Did you hear about the couple who didn't know the difference between Vaseline and Putty??
All their windows fell out.
Re: Dash Problems
As suggested, eliminate the simple things first - check & clean block connectors/connections first, then get batery checked, then start looking for harder/more expensive things ......
Re: Dash Problems
My dash on the KTM went all erratic just before the reg/rec failed. Would lose the speedo and the rev counter needle would stop working for a while,then it would all come back on. Despite testing the reg/rec with a voltmeter with the bike running and all showing normal it still boiled my battery. Changed the reg/rec and everything is ticketyboo again.
Re: Dash Problems
had them issues a fair few times all the times it was R/R or Generator or Battery. Oh im fixing my my Generator at the min from same issue
Mini_Beth
Re: Dash Problems
Ok Thank you everyone. Connections have all been checked and they're
ok so will have a look at changing the reg/rec
