Going up Porlock hill two up
Kata
First Name: John
Re: Going up Porlock hill two up
Post by Kata »
The gsxr solo is straightforward up there btw so there's something in the fjr being a lump.
I have seen a BMW rt(?)1600 two up doing porlock hill and I must say I was impressed.
pieeater
First Name: Paul
Post by pieeater »
Kata wrote: Oct 17th, '18, 21:54 The gsxr solo is straightforward up there btw so there's something in the fjr being a lump.
Having gone through the obvious I'd be looking at the suspension setup as it could be the steering geometry is off causing it to run wide. I'd definitely check the preload front and rear (static / rider sag) as too little will cause the bike to drop at the front and / or back which will throw the geometry out. If the bike is of an age then it might be worthwhile having the forks / shock refurbished.
pieeater wrote: Oct 18th, '18, 12:42
At 30-40mph + maybe, but I'd suggest that at walking pace suspension set-up will make cob all difference. You could replace the shocks with lumps of wood and it wouldn't affect things too much. I think these things can be over-thought a little. JFDI. :-? :))
Robbo87
Post by Robbo87 »
[/quote]
. . . . . . . At 30-40mph + maybe, but I'd suggest that at walking pace suspension set-up will make cob all difference. You could replace the shocks with lumps of wood and it wouldn't affect things too much. I think these things can be over-thought a little. JFDI. :-? :))
[/quote]
Succinct and to the point, and correct!
JFDI - =)) !
jer r1
First Name: jerry
Post by jer r1 »
Running wide is usually caused by turning in to early and target fixation when you start running wide. The fjr is quiet stable at low speeds even when fitted with panniers.
KEEP CALM
AND
POWER ON
Kata
First Name: John
Post by Kata »
Yep it's stable at slow speeds.
Think your right. Going to try Mr B's suggestion. First with gsxr to get confidence back then again with the fjr.
jer r1
First Name: jerry
Post by jer r1 »
Is your pillion experienced, could be pulling you wide.
KEEP CALM
AND
POWER ON
If you approach said bend with at least 60mph and brake hard to the apex whilst looking as far ahead as possible (not fixated at the tarmac right under you) just point and squirt - simples :twisted:
Kata
First Name: John
Post by Kata »
ptolemyx wrote: Oct 19th, '18, 18:07 If you approach said bend with at least 60mph and brake hard to the apex whilst looking as far ahead as possible (not fixated at the tarmac right under you) just point and squirt - simples :twisted:
:-bd :)) :)) :))
Anybody tried Millook near Bude 2 up on a biggish road bike , i have only ever done it on the the big thumper honda trailie tpye thing
Kata
First Name: John
Post by Kata »
This looks useful.
https://youtu.be/-qJXO4CZ9S0
Kata
First Name: John
Post by Kata »
This looks useful.
pieeater
First Name: Paul
Post by pieeater »
TLS-Moose wrote: Oct 19th, '18, 08:54
Fair enough - I just thought that if the geometry is out then the center of gravity would be too which could affect low speed steering round bends, going up such a steep incline would also affect the center of gravity which could compound the problem. I may well be guilty as charged of overthinking the problem though it just seems a shame that an otherwise capable bike appears to be having these issues.
Kata
First Name: John
Post by Kata »
Actually imho the suspension can have an effect at slow speed. More the front forks than the rear.
If I change between neutral and slight acceleration there's fair bit of fork movement. Think that's due to the back sitting to far down as the stndars rear shock isn't really first for purpose on the FJR.
Yes it would help if I was smoother but the clutch is hydraulic and a bit on-off compared to the slick gsxr cable actuated one.
Excuse 23 (c) me 2018
Got to say have not done a lot of 2 up riding but when I do it is not that enjoyable as a ride. That said Gixxers are not the best bike for 2 up riding and basically all of the weight of the passenger ends up leaning on the rider so not so great. From a handling perspective just due to the extra weight it is going to make changes to everything you do as speeding up, slowing down and turning will require you to move more mass then usual. Feels odd....
