off Road bike setup.
Re: off Road bike setup.
Drop the gearing to keep the revs higher, that way wont be as lumpy as trying to run on idle
Have checked the jets and some have been replaced. The grey wire removed to change ignition timings and needle was on a different notch.
Ducaki is gonna pop round to double check stuff and then hopefully things will go back to running ok.
Just need to source some jets.
