Satnav driving me nuts.
Look in here for 'How to' guides that have been donated to us...
Crusader Sport
First Name: Steve
Post by Crusader Sport »
Putting in the town waypoints for 9 Aug fun ride. All ok till I get to Ivybridge then after putting in the waypoints for the Southern part of the ride the satnav ignores them and takes the shortest route to the end point of the ride. Spent hours on this trying different settings including a reset to factory specs. No difference. HELP please.
2019 T120 with Hagon 2810 shocks.
Re: Satnav driving me nuts.
Just follow the Bike in front.
That's all I'm doing. :)):
Ming
First Name: Andy
Post by Ming »
billinom8s wrote: Jul 28th, '20, 16:59 Just follow the Bike in front.
That's great advice.
Unless you're the run leader.... :))
KTM 1190ADV - sold
KTM 790ADV - sold
KTM 790 Duke - sold
Honda CB300R - sold
Honda NC750X DCT - sold
What sat nav have you got and how are you imputing the way points?
If you're the run leader it doesn't matter either - everyone follows you, so as long as you don't share the exact route in advance, give the outward appearance of knowing where you're going, & retain an air of confidence, who's to argue with you? :-bd =)) =))
Post by MellowYellow »
TLS-Moose wrote: Jul 28th, '20, 19:05 If you're the run leader it doesn't matter either - everyone follows you, so as long as you don't share the exact route in advance, give the outward appearance of knowing where you're going, & retain an air of confidence, who's to argue with you? :-bd =)) =))
Known as 'méthode nomatique'.
Ming wrote: Jul 28th, '20, 18:23
I knew I forgot something.
Have to say I am kind of with Moose on this one as long as you get where you want to go and don’t end up trying to ride up a farm track with more grass then tarmac then think your all good
However to try and help answer your question it depends on the sat nav as they are all slightly differant. But you need to choose your way point carefully else they will not be serving a purpose. Also there is normally a choice on the route settings if you want the shortest, fastest most direct might want to play with these setting to see if this helps.
Crusader Sport
First Name: Steve
Garmin 595. I was putting waypoints in using "add location" which were ignored AFTER saving the trip. I have tried the different " route settings" to no avail. Following bike in front is a genius idea, of course if the drop off system has blown up ( like on Sunday) the TEC ends up on the way to bloody Plymouth.
Use Garmin Basecamp.
It's free and uses the maps that are in your Sat nav.
Plan the route in Basecamp then send it to your device as a track.
Then either tell your device to follow that track as a route or just show the track on the screen so you can at least see where you should be going,
royb
First Name: Roy
Post by royb »
menzies3032 wrote: Jul 29th, '20, 08:14 Have to say I am kind of with Moose on this one as long as you get where you want to go and don’t end up trying to ride up a farm track with more grass then tarmac then think your all good
Where's your sense of adventure Robert; It's more fun, and certainly beats speed traps on main roads.
Back in the room I can't even see my satnav in sunshine, and cannot hear the ruddy thing either.
Crusader Sport
First Name: Steve
Went to Lynton yesterday and figured it out in the car park. Added bonus I had a go at car driver parked in bike bay then warden turned up and nicked the rest, happy days. Thanks for all your help.
Did you then go on to Combe Martin?
Crusader Sport
First Name: Steve
Nope, went back via Simonsbath ,Dulverton ,Tiv then back to civilisation in East Devon. On way to Lynton wanted to go on that brill road from Tiv to Witheridge but the road was shut so got to With via Rackenford. Not going that way again, went through pot hole central on lanes.
