Wheel rim bead out of alignment
Kata
First Name: John
Post by Kata »
Just had a couple of advisories on my MOT saying that the rear wheel has a slightly distorted bead rim either side. Weird as it wasn't on the last mot they did a couple hundred miles before and I've not hit any potholes but anyway....
Just been to platinum wheels and their equipment to test/repair won't work on bike wheels.
Any where that can fix this?
I could probably buy a second hand wheel but might end up with same issue!
Jug
First Name: Rich
Re: Wheel rim bead out of alignment
Post by Jug »
Are you sure it's the wheel and not just the tyre?
Should be easy to rig up something to check it while it's still on the bike, just needs a securely mounted pointer from the swing arm.
Kata
First Name: John
Post by Kata »
Pretty confident it's the wheel, assuming they actually tested it in the MOT and didn't just try to drum up business. I can't actually see any change in the line on the side of the tyre and the wheel. Phil fitted it.
As for rigging a pointer, I'll have to think about that. Cheers.
