Sunday 24th May
- Guest user
Re: Sunday 24th May
Home okay after my right front caliper problem. Soon got used to only using the back brake, surprising how efficient stopping is with just the back. Front was working after it cooled down but I wanted to prove a point. Dazzer must follow me on the next ride to see rear only braking
Bilko1000
- First Name: Darren
Re: Sunday 24th May
Glad you got home safe Bri lucky you didnt need to do an emergency stop though! for any reason.
R1M 2020 Model / FIREBLADE 2019
- Guest user
Re: Sunday 24th May
Upping the hazard anticipation and riding accordingly minimised the risk. You can actually stop quite quickly with just the rear brake. I did have the back up of the front brake working again if I needed it. I assume 750+ miles riding in rain last week must have got enough crud in by the pistons of that caliper to cause it to drag and end up binding and overheating. I am a naughty boy for not having the calipers off for a good going over when I cleaned the bike. Will do a full rebuild and change the brake fluid now.
Re: Sunday 24th May
Pleased to hear that there was no bad outcome of you brake problem Brian
www.MotorcycleInfo.co.uk
Motorcycle Info Pages
Red5
- First Name: Nick
Re: Sunday 24th May
To brake is to admit defeat anyway
