Friday 29th July
- Tvrv37
Re: Friday 29th July
Keep the chain replace the bike.royb wrote: ↑Jul 28th, '22, 10:10 Could be up for this Brian but have a clicking noise from the bandit chain. It has only done 30,000 miles. Do you think it needs changing?![]()
If I solve this problem see you at the toll house outside Chard. If not there then I will not have fixed it and won't be coming - don't wait and have a good ride.
New chain on, see you Brian and Richard at Chard toll house. Has had engine oil wiped over it with a cashmere scarf as per Si's recommendation. If it behaves properly, me thinks this chain will see me out.Tvrv37 wrote: ↑Jul 28th, '22, 13:58Keep the chain replace the bike.royb wrote: ↑Jul 28th, '22, 10:10 Could be up for this Brian but have a clicking noise from the bandit chain. It has only done 30,000 miles. Do you think it needs changing?![]()
did you do the sprockets too?
No, I'll live with the sprockets that are on even though, I accept others may disagree.
Good for you Roy. Just reverse each sprocket so that the hooked teeth face the other way and they'll see you out too
Already done that Phil but for a different reason. The 180 x 60 x 17 rear tyre was rubbing the chain so reversed the recessed sprocket (2mm) to gain clearance for the tyre. Probably slight misalignment but hey ho it's not the end of the world and the bandit can live with it.
The tyre certainly can.
Thanks for leading Brian and thanks to Roy for bullying me about my rear light.
I've since decided that you're probably right so I'm now shopping for LEDs.
About the ride...
Traffic was shit, route was OK, coffee stop was nice, company was great, as was the weather.. so all in all not too bad.
See you on the next one guys.
About the ride...
I used to run a 190 on my bandit didn't have any trouble with the tyre rubbing Roy
MV 800rr brutale
MV 800 turismo veloce luso
Did you say the traffic was shit....no it was hypershit. Of course we could have set out at 04.00...
Roy needs "real" new tyres now in any case. Far more important than Richard's feeble tail light being upgraded.
Yes.. it makes sense now why Roy was refusing to lean his bike lol.
It's the new slick style isn't it Roy
MV 800rr brutale
