protecting the rear suspension - ZH2
It's such a pain cleaning the rear shock and suspension linkage. I've just had to replace all the linkage bearings etc. So in true shutting the stable door after the horse has bolted fashion I've just made a mudguard to keep some of the crap at bay. 4mm epdm rubber zip-tied in place:-
Re: protecting the rear suspension - ZH2
Nice one. I trust you've secured the patent?
Neat, you'll hardly notice it there either once the wheel is back in.
My 1190 has got something similar to that.
Nice solution there Herr P
. I did almost exactly the same on my Sprint, not to keep road crud off the shock but the single side swinging arm linkage. Also, when I dismantled and serviced the linkage I squeezed rubber O rings into the gap between the SA and the top linkage bolt - a new mod for an old and ongoing issue with these bikes. So, a sort of belt 'n braces fix - a little extra work initially should save potential prob's later - that's the cunning plan anyway
Nice, that'll make a big difference and is easy to remove/refit when working down there.
Good effort and should make a world of difference for cleaning
Good bit of innovation there. Worth checking every so often just in case the rubber wears through the zip ties.
I'll know that's happened when the rear wheel locks up
