zzr 400 wnt start after a ride
the bike starts perfectly on the first self without throttle when cold but after i take it out on a ride n it gets a bit warm n i turn it of and start again it will kep on piking the self but the engine wnt start n there is a cliking sound from the fuel pump but if i wait for about 20 mins it will start again in a jiphy......the bikes runing condition is perfect goes all the way very smooth....expert help plz
Re: zzr 400 wnt start after a ride
And you are who ? It's normally polite to introduce yourself before just asking for help.
- Stikley
- First Name: Nik
Also can you type in English as I don't understand half of it.
1994 Kawasaki ZX9R
2002 Aprilia RSVR
2002 Triumph Daytona 955i
2002 Suzuki AN400 BurgerVan
2005 Kawasaki KXF250
2011 Citreon Relay LWB
Oldskool bikes rule!
2002 Aprilia RSVR
- Stikley
- First Name: Nik
And spell checker problem too, Check the coolant level in the rad and overflow bottle, do it when it's stone cold though!
1994 Kawasaki ZX9R
2002 Aprilia RSVR
2002 Aprilia RSVR
wow you guys do criticize the new guy must be enticing rite ;p btw i m Ahsan n the just replaced the coolant so i don't thinks its that and the bike doesn't heat up it goes on fine but its when i turn it of it doesn't start
What happens when you press the starter ? Does it click ? Does the engine try to fire or is it silent ?
Could be coils breaking down. Does it try to fire ?
when the bike is cold it starts up immediately but when its warm it does fire takes a long self but the engine doesn't start.....
- Stikley
- First Name: Nik
How does it sound when you go to fire it up, is it turning over normally and not firing?
Could be Regulator / Rectifier not working? Not charging the battery but as the battery stands still it regains charge? Maybe, could be a number of things, where abouts are you based?
1994 Kawasaki ZX9R
2002 Aprilia RSVR
2002 Aprilia RSVR
Valve clearances done recently?
if there out of tollerance when a bikes hot i think they make it hard to start..?
'94 FZR600R
'02 ZX636 A1P
'94 FZR600R
'02 ZX636 A1P
- Stikley
- First Name: Nik
Valve clearance was gonna be my next suggestion, just easier to check the charge first as doesn't involve removing engine bits first
1994 Kawasaki ZX9R
2002 Aprilia RSVR
2002 Aprilia RSVR
I would also agree valves must be out , its just text book how you let the bike cool and its fine again , could though in all fairness be the plugs knackerd and need changing maybe ?
