euro pits power supply
Posted: Aug 28th, '14, 22:06
by Red5
Off to Portimao end of October. Can anyone say with genuine knowledge what the plugs are in the pits there?
Are they the round blue 230v 16A power sockets?? Trying to decide which extension leads to take.
Re: euro pits power supply
Posted: Aug 29th, '14, 16:35
by yellowrsvr
Inside the pit garages are the usual two pin euro plugs. These are limited and we had trouble with the RCDs tripping due to the load.
Depending on which garages they use, there is some blue water tight sockets outside the back of the garages.
Posted: Aug 29th, '14, 18:01
by Red5
That's the badger... thank you. Ill take the blue 16Amp sockets, though the "water tight" ones, if I'm thinking the right thing, are the screw up connections.
Seems a bit naff if the only 16 Amp sockets are out side, as that's a fairly standard connection for loads around the world.
Posted: Aug 29th, '14, 21:12
by yellowrsvr
Red5 wrote:That's the badger... thank you. Ill take the blue 16Amp sockets, though the "water tight" ones, if I'm thinking the right thing, are the screw up connections.
Like this:
Posted: Aug 29th, '14, 22:24
by Ruffian
Usual caravan power sockets use the above also,
Posted: Aug 30th, '14, 18:24
by Red5
yellowrsvr wrote:Red5 wrote:That's the badger... thank you. Ill take the blue 16Amp sockets, though the "water tight" ones, if I'm thinking the right thing, are the screw up connections.
Like this:
Yep, that's the one. Standard 16amp, 230v socket. But you reckon theirs tripped quite readily? A few sets of tyre warmers, charger or 10 and even a fridge... Not as much as a full pro race team. Should be made for it. We'll find out.
