PC Noise
PC Noise
Hi all, everyday at the same time my PC Beeps for about 20secs and then stops beeping, the pc still works fine throughout!! any idea how i can get this beeping to stop?? or what is causing it to beep??
svr-ash
Post by svr-ash »
Does it beep straight after you turn it on, thats the BIOS telling you somethings wrong, undo the case bolts and make sure nothing has worked loose when you moved it, then go into the BIOS (setup when you boot up) and make sure the date etc are all correct :wink:
I know if i unplug mine, i need to reconfigure the BIOS to run the video through the PCI not the AGP and the LAN is turned of and the clocks wrong :roll:
speedy(delboy)
Post by speedy(delboy) »
Probebly just your internal battery low, needs replacing,
I think its on the motherboard
chris_1127
Post by chris_1127 »
you havent dropped your digital watch down the back of your computer have you Jay? :lol:
gsx-aaaaaaaargh!!!
jim1979
Post by jim1979 »
Like Speedy said prob just battery on the motherboard needs replacing. Either that or more than likely you need to remove the ram, blow the dust out and refit it. Could also be that your running your graphics card flat out and its getting too hot. Failing that look here to identify your problem. http://www.uktsupport.co.uk/reference/biosb.htm
Jonny
First Name: Jonny
Post by Jonny »
If its still working perfectly (with the exeption of the beeping) there are only a few possible problems.
Firstly and probably most likley is that a fan is clogged with dust and stoped spinning.
Hardware failure is another possiblilty but I wouldent say its likely becasuse you said your pcs working ok.
Another cause could be the battery problem but I would say that is the least likely, Every new pc charges the "CMOS Battery" while its plugged in the wall provided the switch near the power cord is on.
If your under waranty, let them sort it. Most warrantys are invalid as soon as you take the side of your pc case off.
If it isnt, my sugestion (and IT hardware is my job) would be to turn it off, when switching it on again go into your systems CMOS menu. this is usually acomplished by presing the "Delete key" repeatedly after you turn your system on. You will probably be presented with a blue screen with white writing. You want to select "Power and Management Features". In this screen you should see things like temperature readouts and fan speed in rpm. if you see any fan speeds at 0, write down what its labeld as and post it here. If you get stuck im on msn at h4z7d@hotmail.com
Good luck!
If it's at exactly the same time each day then it could be an alarm feature either in windows or the BIOS. Try changing your clock back an hour and see if it beeps at the same system time.
age
Post by age »
Take a Hammer to it !!!!
Age
PS3 name lesnage
baskie
Post by baskie »
jim1979 wrote:Like Speedy said prob just battery on the motherboard needs replacing. Either that or more than likely you need to remove the ram, blow the dust out and refit it. Could also be that your running your graphics card flat out and its getting too hot. Failing that look here to identify your problem. http://www.uktsupport.co.uk/reference/biosb.htm
it only beeps on start up. and if hes only got one sticvk of ram it wont even start up. the miost liekly thing is the battery. just chnage. very rear for them to run out to be honest. but never mind
Dave
Post by Dave »
Find out what motherboard you got, then look on the manufacturers website and you should be able to look up some sort of beep code.
Some motherboards have a temperature setting, mine won't turn on at all as all I get is the beep which means that the temperature sensor has buggered.
Hope you get it sorted soon mate
Stinky
Post by Stinky »
This wouldn't make sence if it happened the same time but you might want to cheak your graphics card tempurture. And maybe stick the overheating warning beeps to a higher level.
Potential Royal Marines Course: 27th Feb o7 - Fail
Infantry Basic Training - 18th November 07 - ?
Xbox Live Tag - StinkyUK
speedy(delboy)
Buy my spare one off me, mega good spec as well, velly cheap
