Any help please
rastas
Any help please
Post by rastas »
hi guys any ideas on this one please. it is for my bro in law.
i have a yz426f 02 and i striped it to powder coat the frame(having the bike mot before i did it)and now that i put it all back together i have lost my spark!!!???i have use my mulitmeter along with the manuel and every thing seams to be with in what its suposed to be .now im stuck for a reason can anyone please shed some light!!????
cheers
Nige
Rode an SV650 now rides a ZX636R GREEN now rides a aprillia rsvr
Powder coating nice thick coat of plastic all over the frame, you need to scrape off some to get a good earth again where things earth to the frame
baskie
Post by baskie »
Mervin wrote:Powder coating nice thick coat of plastic all over the frame, you need to scrape off some to get a good earth again where things earth to the frame
bingo, check fuses. ht coil? got a spark comming out of the spark plug? but yeh deffo need a good earth.
nice choice of bike btw ;)
rastas
Post by rastas »
yep done the earth point. no spark from the ht lead when kicking it over. there are no fuses. no lights or any thing fitted.
cheers
tony
Post by tony »
can the engine actually earth?, go around and check continuity between battery negative terminal and engine, mounts etc
Ive seen people desperately trying to sort out ignition problems on rubber mounted engines DOH they forgot to fit the earth strap!!!
but if it all worked before then check earths and also check the kill switch, if it earths through the bars, check the bars are earthed
a mate will come bail you out of jail. But a true friend will be sat next to you in the cell saying "jeez that was fun!"
If you want me Im on the other end of 07710 424947
