diary of how to destroy a DT
- fluffybunny
Re: diary of how to destroy a DT
ok so it was a new battry that it needed but now i have a new oil leck lol this bike is a night mare
[img]http://i417.photobucket.com/albums/pp253/fluffybunny5353/swbsig.jpg[/img]
Johnnyb
perhaps that white plastic thingy from out of the carb, just a thought.......
- fluffybunny
yep put that back now j put showed me how ues this silacon stuff to re seal engian and my mate tock bits in to work for me to get the weldid so everybody keep your fingers crossed as i am goin to take it out this affter noon (i have credit on my phone and apdave on stand by to cum get me when i brack down ) so wish me luck !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
spankingtigger
where you gunna go?? if you were going now i would go with you got a funny day off this week lol
- fluffybunny
it is with a heavy heart i wright this as it will be the last about the DT as he is no more !!!!!!
and y the [censored] did some fool right " DO NOT OPEN " on a cap if i was ment to take it off and put coolent in it
so the little shit will be goin on ebay as a non runner tomarrow
Jesta
Jynxed yourself, anyway better the engine seize than realise that the petrol smell you had been smelling for weeks and having poor miles per gallon is because the sealing ring on the fuel pump has given up and is spraying fuel all over hacked up wiring loom (had an imobiliser fitted that was hardwired in) and onto the hot regulator. Lucky I caught it before I caught firefluffybunny wrote: (i have credit on my phone and apdave on stand by to cum get me when i brack down ) so wish me luck !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
sheet sounds a bit dodgy that wiring fuel mix
merv
merv
chris_1127
probably for the same reason that Aprilia felt the need a few years ago to warn people "not to attempt to dry clothing or small animals on any hot part of the bike" in the owners manual...fluffybunny wrote: and y the [censored] did some fool right " DO NOT OPEN " on a cap if i was ment to take it off and put coolent in it
gsx-aaaaaaaargh!!!
R.I.P DT
Jesta
btw i had no hand in this, dave was claires assistant. I told him not to fill the expasion chamber because its not connected properly, has only overflow not the ability to re enter engine, someone had changed the tubing over and sealed one end.
Banditmax
Jesta most bikes only have one tube from the expansion bottle to the radiator. It works as an overflow and a vaccuum tube for when the water expands and contracts.
Jesta
Since when? You have one for overflow and one for allowing it back into the engine, thats two.
- fluffybunny
i am not blamin any one but me !!! and dave read the same ' DO NOT OPEN ' thing as me and thought the same as me it ment we were not ment to open it ,not dont open unless u want to put coolent in here
My TL only has the one hose from the bottom of the expansion tank to a spigot immediately under the radiator cap, other than the cap (rubber bung) used for topping up the coolant.Jesta wrote:Since when? You have one for overflow and one for allowing it back into the engine, thats two.
Do DT's really have fuel pumpsJesta wrote:because the sealing ring on the fuel pump has given up and is spraying fuel
Thas a shame about the DT though
- fluffybunny
Is it too far gone to fix
Are you gonna get another bike
[/quote]
well it is sesed ( the piston is stuck for them who cant work out my spelling)
but as u can tell from all the rest i have never had it runnin right and every time i fix one thing ( with help from my ace house mate ) some thing elas go wrong !!
and i have just got a bit dishartend with it ,
i dont know if i can get a new one yet as i still have not finished payin for the DT and i am about to sit my DAS so need to get the money for that 2 i might just wait till i take the test and then start lookin for some thing cheap and a bit biger
but all do me a faver and if i look like i might start tryin to do any of the mantence my self slap me .
i should not even be aloud to fill up the oil !!!!!
