Nail in back tyre
gooner
Nail in back tyre
Post by gooner »
Hey all,
Just like to know what u guys would do if u found a nail in your back tyre. This is the second time in 4 months, the first time i replaced the tyre, now its happened again i'm looking at another £160.00 bill :evil: . What are the other options and what risk's go with them?
I need a quick response guys as i will need it for Sunday..
Thanks
Stu :)
tutton
Re: Nail in back tyre
Post by tutton »
Depending on where its gone in
if its the sidewall, or very close to the edge you cant do this!
But usually most bike shops will plug the hole, which is a good repair, some people have questioned the strength of these but others have went 160mph and it still held up.
So tyre plug id say usually around 20 quid mark in a local bike shop.
'94 FZR600R
'02 ZX636 A1P
1. As said above, if it's near the centre of the tread get it plugged - but be warned many tyre places will not plug a ZR rated tyre ...... :roll:
2. What sort of/size tyre is it that costs £160 .... I'd be expecting a pair for that :shock:
jam
Post by jam »
Nothing wrong with a proper repair in a tyre, I've done loads over the years. I prefer the damage to be in the centre 60% of the tyre and the obstruction must have pierced the tyre as near to 90deg to the tyre rather than at an angle, but a repair carried out with the correct type of 'plug/mushroom' should easily last the life of the tyre. Legally you can repair a tubeless rear tyre twice, but I'd rather only use one. I don't usually repair fronts unless the puncture is dead square in the middle. Most tyre centres will repair it if you take the loose wheel into them.
Mike Daytona600
Post by Mike Daytona600 »
Yep I've repaired loads. Just as long the customer knows it's their decision. I'd much rather plug mine than buy a new tyre.
Parker's
Valeting
Service
Tel: 07751883056
gooner
Post by gooner »
Thanks for the replies.
The nail's just of centre. The tyre make is a ZR17 Pirelli dragon supercorsa pro. Now just have to find someone who will do it at short notice. If that fails, i could steal the old mans blade for Sun :)
Cheese Monkey
Post by Cheese Monkey »
Had it done twice myself, never received any paperwork or receipts either time from either place, covering tracks just in case methinks. Held up fine both times though 8)
SteveR3
First Name: Steve
Post by SteveR3 »
Always keep a small can of Tyre Weld on-board, has worked for me many times in the past and seen the tyre through to finally wearing out :D
Steve.E
tman
Post by tman »
I run on Avon Vipers. They replace the tyre if you haven't used more than the first mm. No questions asked includes accidental damage too I believe.
[i]Everything isn't meant to be ok[/i]
[img]http://i723.photobucket.com/albums/ww235/blackburbstayup/sig_P1020370-1.jpg[/img]
it depends on where the nail is in the tyre. if its in a 'safe' area i simple repair for like 20/30 quid or so can be done..where they stick i rubber mushroom out through the inside of the tyre which seals up the hole. or you could try some duck tape?
Banditmax
Post by Banditmax »
Duck tape????????????? that has to be the funniest thing i've heard in a while :roll: :roll: :roll: :roll: :roll: . Although it is a very useful tool, its definately not the one for this job. If your tyre blows out mid corner and you slide into the oncoming trafiic and die or get seriously injured i think you'll wish you payed out for a proper repair job. To be honest they wouldn't even be allowed to sell plugs for tyres if they were not safe to use.
Banditmax wrote:Duck tape????????????? that has to be the funniest thing i've heard in a while :roll: :roll: :roll: :roll: :roll: . Although it is a very useful tool, its definately not the one for this job. If your tyre blows out mid corner and you slide into the oncoming trafiic and die or get seriously injured i think you'll wish you payed out for a proper repair job. To be honest they wouldn't even be allowed to sell plugs for tyres if they were not safe to use.
was jokin dude :lol: i wouldnt even use duck tape on my push bike :? ahaha
LITTLE LURCH
Post by LITTLE LURCH »
just use expanding foam it works a treat :)
dougal_999
Post by dougal_999 »
Got a nail in my back tyre a few days ago (I say nail... more like a huge stud) took it into college and got a mushroom repair done on it, I was told it lowers the speed rating by one rating though, just so you know. I realise this post is a bit late but oh well :)
