The big difference between C and E/F models is in the motor, the C model uses steel liners, and the later models used an ally plated bore, bottom ends are the same, crank and rods are the same part number for C/E/F models and Z750/1000. Power output is usually around the 135bhp mark with a full system and filter/jet kit. With a Wiseco 973cc bigbore it is easily possible to see over 150bhp from the motors, and slightly more with a 998cc JE piston kit. Relinering is cheaper than boring and replating the ally cylinder bores. I'm currently building a hybrid Z750/ZX9 bigbore motor using different pistons which should achieve 1022cc and at least 160bhp.
well if you change your mind about a TLs my mate is selling his, its P reg and he`s looking for £1950 ono, I rode it the other day, not scary at all and they do sound the nuts
[b][color=#FF0000]wait till you see god [size=150]THEN[/size] brake !!![/color][/b]
zx9r, cant fault motor, sounds , but steers like a tanker and no good for trackdays unless your an ape. but i stll like them. im a kwaca man and would only have zx6r or zx10r. cant beat zx7r for looks and front end though. if i didnt have kawasakis i would have a sp2
the stories about the tls being scary are complete bollocks! i had one with standard set up,just a set of harris cans on and was a great laugh. they have a lovely punch to them with great instant power but aslong as your not being a nob and dropping a couple geasr and cracking it open mid-corner then theres no problem!
