Chain tension bolt - siezed & sheered - Help
Probably gonna get completely slated for this.. :roll:
The photos explain it all...
Completely siezed..good old Kawasaki and they're resistance to corrosion. :x The head's sheered off trying to get the thing out! Wheel ain't moving/goin outta line i've been riding like it for a couple months.. luckily it's not on the chain side. Ive got stainless steel replacements to go in. Chainside tensioner is fine but this one's well and truly f*cked..
I know the only way to do this is to either heat the swing arm up and use an extractor tool or drill it out and thread a new hole etc.. But I don't have any of the tools to do it. £50 to anyone that can get it out leaving the thread intact and paint on the swingarm!!
Tom :)
Varcon
First Name: Edd
Re: Chain tension bolt - siezed & sheered - Help
Post by Varcon »
That sounds like a challenge! When you free for me to attack it?
Oh, and.... =))
Soak it well with WD40 or plus gas or such, does the sliding bit come out to give you better access? then take a hammer and punch and give it a few sharp taps then try to turn it with mole grips slowly does it though. if you get it to move a little one way do not force it too far and shear it off again, just wind it back again then forward again , keep adding lubricant and working it back and forth moving it further and further in little stages eventually hopefully it will come out
Merv
As Merv said, but once you've soaked it for several hours in WD40 or duck oil then heat the crap out of it with a blow torch till its red hot then try turning it with mole grips. Otherwise if you have access to a welder weld a bolt to the remaining stud and try turning it that way. Took three goes and several soakings with wd beforeI got a stud out of of my old Bandit barrels.
Slow and steady is the answer.....
Oh and like Varcon said...... =)) =)) =))
Buy a new bike
tony-klr
Post by tony-klr »
you might get lucky and get it out, but I will be very surprised
as already mentioned, I would give it liberal soakings in a penetrating oil, leaving it for as long as possible.
heat applied to the bolt will help but its the alloy you want to get warmed up, as it expands faster than the steel
dont go heating the bolt until its cherry red etc, then you are screwed LOL, probably a hardened steel bolt originally, heating it to cherry red then letting it cool, will soften it.
good vice grip or mole grips will be a help, not cheap shitty poundland ones
not a lot of room for movement in there, but good luck with it
if you do get any movement, then as already mentioned, dont be in a hurry to rush it out, work it back and forth, like your tapping a hole, let it work its way out.
Serlant
Post by Serlant »
Were it mine I would use a Dremel to cut a slot in top of the bolt, then do 2 nuts up against each other ontop of the slot, then stick the biggest flathead screwdriver i could in there(on second thought would probably use a flathead hex bit on a ratchet with an extension) and undo it slowly. all this while soaking it with wd40 etc.
Cheers for all the replies guys gonna give it a go when I get a bit of time this week. Will let ya know what happens
GIXXER KID
Post by GIXXER KID »
how much is a new swingarm on ebay? =))
[img]http://i106.photobucket.com/albums/m247/I-LUV-TRIALS/banner.jpg[/img]
Heated it up, beat the sh!t out of it with a hammer, penetrating spray and a dirty great pair of moley's and it's out ..although now half the paint's missing :roll: :lol:
Thanks for the help - What a c#nt\!
Oh and Adam - They're about £150 ish seocnd hand :shock: :lol:
GIXXER KID
Milky wrote:Oh and Adam - They're about £150 ish seocnd hand :shock: :lol:
OUCH!, i can probs get an r1 swingarm off ebay for about £40 :P haa
freeze
First Name: Tom
Post by freeze »
don't forget the copper lube when you put the new bolt in, will stop it happening again!!!
Most motorcycle problems are caused by the nut that connects the handle bars to the saddle.
Result Milky. years of working on rusty old crap teaches you these things
:-bd
Oh and well done Milky ;) ..
