This will be my first attempt at anything mechanical on the bike. I've done plenty of stuff on my cars, from changing wheels, all the way to engine swaps, suspension rebuilds and brake rebuilds, but I'm a bit unsure with the bike. Is there much difference? am I likely to run into issues bleeding the brakes? I've got a pressure bleeding kit for the car, but I don't think it's going to fit on the front brake fluid pot
The reason for doing it is that I'm pretty sure the front brakes are binding. If rebuilding the callipers don't work, I'm assuming it'll be new discs and pads?
I'm going to go into Exeter tomorrow to find CMS and get a new seal kit for it, and I've already got some ATE super racing blue (dot 4) that I can use for it.
Does anyone have a write up or a guide to rebuilding and/or rebleeding them? Is there an easy way to rebleed the front brakes?
Thanks in advance
