but I had not given much thought to how i would get the bike on the stand by myself.
can someone advise me on the following;
which stand would be best
how do i get it on the stand by mysef without it falling over
by the way i am 73 yrs old
dave
Jim, could the Abba model you have fit onto my 54cm wide lift bench? Might be a handy thing to have, save all that stripping off of plastic to get both wheels out at the same time.Gimlet wrote:I prefer Abba Superbike stands with the front wheel lift bar for garage use on my own. Takes a few seconds longer than paddocks but you can get both wheels off the ground with one stand, its totally secure, leaves the swinging arm/rear spindle area and front forks/headstock unencumbered and with the correct adaptor one stand will fit any bike.
http://abbastands.co.uk/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;"
That would depend on the width of your bike, as the fixings slide along the bottom rail. As you pull the stand over to take the weight off the bike, the feet at the bottom would need to land on your bench.Robbo87 wrote:Jim, could the Abba model you have fit onto my 54cm wide lift bench? Might be a handy thing to have, save all that stripping off of plastic to get both wheels out at the same time.Gimlet wrote:I prefer Abba Superbike stands with the front wheel lift bar for garage use on my own. Takes a few seconds longer than paddocks but you can get both wheels off the ground with one stand, its totally secure, leaves the swinging arm/rear spindle area and front forks/headstock unencumbered and with the correct adaptor one stand will fit any bike.
http://abbastands.co.uk/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;"
650 mm is the full width of the stand, the widest fit of my bikes is the 1290 KTM which is about 600 but the other two are within an inch of that so you could say 600 mm for most bikes. Depends of the length of the adaptor pieces as well. They vary.Robbo87 wrote:Jim, could the Abba model you have fit onto my 54cm wide lift bench? Might be a handy thing to have, save all that stripping off of plastic to get both wheels out at the same time.Gimlet wrote:I prefer Abba Superbike stands with the front wheel lift bar for garage use on my own. Takes a few seconds longer than paddocks but you can get both wheels off the ground with one stand, its totally secure, leaves the swinging arm/rear spindle area and front forks/headstock unencumbered and with the correct adaptor one stand will fit any bike.
Thanks for the numbers Jim, saves guesswork on my part.Gimlet wrote:650 mm is the full width of the stand, the widest fit of my bikes is the 1290 KTM which is about 600 but the other two are within an inch of that so you could say 600 mm for most bikes. Depends of the length of the adaptor pieces as well. They vary.Robbo87 wrote:Jim, could the Abba model you have fit onto my 54cm wide lift bench? Might be a handy thing to have, save all that stripping off of plastic to get both wheels out at the same time.Gimlet wrote:I prefer Abba Superbike stands with the front wheel lift bar for garage use on my own. Takes a few seconds longer than paddocks but you can get both wheels off the ground with one stand, its totally secure, leaves the swinging arm/rear spindle area and front forks/headstock unencumbered and with the correct adaptor one stand will fit any bike.
You could always bolt a piece of 1/4" chequer plate across the centre of the platform to widen it when the stand is being used.
Actually I lied. The spigots may be 600-650 apart but you need to take account of the foot the stand rests on. So really the minimum width required is 700 mm. And then the foot will be right on the edge of the ramp. Widening plate required I would think.Robbo87 wrote: Jim, could the Abba model you have fit onto my 54cm wide lift bench? Might be a handy thing to have, save all that stripping off of plastic to get both wheels out at the same time.
Right, out with the tape measure again! Cheers.Gimlet wrote:Actually I lied. The spigots may be 600-650 apart but you need to take account of the foot the stand rests on. So really the minimum width required is 700 mm. And then the foot will be right on the edge of the ramp. Widening plate required I would think.Robbo87 wrote: Jim, could the Abba model you have fit onto my 54cm wide lift bench? Might be a handy thing to have, save all that stripping off of plastic to get both wheels out at the same time.
many thanks, abba stands looks the best,Gimlet wrote:I prefer Abba Superbike stands with the front wheel lift bar for garage use on my own. Takes a few seconds longer than paddocks but you can get both wheels off the ground with one stand, its totally secure, leaves the swinging arm/rear spindle area and front forks/headstock unencumbered and with the correct adaptor one stand will fit any bike.
Thank you Mr Supermeasure, 720 mm it now is.Gimlet wrote:As chance would have it, as I read that post I just so happen to have a tape measure about my person and the SMT is on the stand outside the door. As fitted to that bike, the maximum width from outside of foot to outside of foot is 720 mm.
