Going up Porlock hill two up
Hi All.
I'm fine going down Porlock hill on my fjr 2 up.
However I only just made it around uphill solo.
Going up hill I went to the middle of the road just before turning in but I still ended up on the other side and it was too uncomfortable for me.
Wtf am I doing wrong?
Re: Going up Porlock hill two up
I did a 3 pt turn first time up there. It's even a trial on a pushbike.
Ive only just realized ive been down it probably a dozen times but never up.
As you get to the hairpin, note to the other side of the road, go past the turn and then pull round for the corner exit.
You can't keep to your side of the road.
Where is this, is it the main road across the top between Porlock and Lynmouth?
I'm guessing it's the 1 in 4 hill out of Porlock village towards Lynton and Lynmouth. My Tiger 800 developed a gearbox fault on there and it jumped out of gear right on the second hairpin towards the top...... not ideal, to say the least
KTM 1190ADV - sold
KTM 790ADV - sold
KTM 790 Duke - sold
Honda CB300R - sold
Honda NC750X DCT - sold
1981 Suzuki TS185ER - very much not modern
KTM 790ADV - sold
KTM 790 Duke - sold
Honda CB300R - sold
You don't know Porlock hill???
Note? So go to other side of road just before?billinom8s wrote: ↑Oct 16th, '18, 19:59 As you get to the hairpin, note to the other side of the road, go past the turn and then pull round for the corner exit.
Wtf u do if there's traffic coming down?!
If it's the hill just after the village then I have done it 2up, and often solo. I just slip the clutch and make the turn. There is one down in Cornwall that seemed steeper & tighter. I was on my SD and decided to swing wide on that one.
Maybe I also do that on Porlock hill, never really thought about it.
Kata wrote: ↑Oct 16th, '18, 20:34Note? So go to other side of road just before?billinom8s wrote: ↑Oct 16th, '18, 19:59 As you get to the hairpin, note to the other side of the road, go past the turn and then pull round for the corner exit.
You look further ahead and adjust your speed. Failing that, ride past the offending vehicle and pull in behind it.
It's all at slow speeds so not a drama.
Now this one is scarey, I went down it 2up but solo on the way out.
Even just pulling away from the pub carpark (solo) almost saw me dropping my Vstrom down that hill.
https://www.google.com/maps/@50.4789074 ... 312!8i6656
This was the one in Cornwall, I was following a guy on a ZZR1400 who took a decidedly wide route around that one.
https://www.google.com/maps/@50.6424763 ... 312!8i6656
Compared to these Porlock is easy. I guess it must just be a big bike thing as the FJR is a sizeable beast.
That first one is just about impossible to get up in a van if it's wet. I got stuck at the bottom when delivering years ago and every other time I had something for the pub I'd have to park at the top and walk down. It's not so bad if you know nothing's coming down as you can be more committed ..
KTM 1190ADV - sold
KTM 790ADV - sold
KTM 790 Duke - sold
Honda CB300R - sold
KTM 790ADV - sold
KTM 790 Duke - sold
Honda CB300R - sold
Taking it too fast? The tricky hairpin bend (going uphill) is best taken in 1st gear at walking pace using the bars to steer round it.Kata wrote: ↑Oct 16th, '18, 17:38 Hi All.
Crikey. Tough scary hills!Jug_Inspector wrote: ↑Oct 17th, '18, 10:19 Now this one is scarey, I went down it 2up but solo on the way out.
Thanks for your suggestion.pieeater wrote: ↑Oct 17th, '18, 15:28Taking it too fast? The tricky hairpin bend (going uphill) is best taken in 1st gear at walking pace using the bars to steer round it.Kata wrote: ↑Oct 16th, '18, 17:38 Hi All.
I'm actual.fact I think I was going a bit too slow for the hill if that's possible. I had to accelerate a bit going around to give the bike more inertia. Which made it better but made me go wider still...
