Sunday 21st June
Re: Sunday 21st June
Won’t be making this as have house stuff to do.
- Guest user
In light of Juggs post at top of page 6 I invited Dave to tag along with the first group bearing in mind Phil (Robbo) said he's only doing part of the ride. That still stands but perhaps Nick and his friend could, as suggested, do the third group setting off at 09.30 so Juggs and Claire can still tag along with some of the gang as we sail through Chard. That leaves Dave open to either group. As it stands I'm expecting him to leave at 9.00 with me....his call. I'm sure all will be clear in the morning
1960 BSA A10
1960 BSA A10
at least something will be
Aye. It’s a bit like herding cats this isn’t it ... and into groups of six at that LOL!
Was in a group of 12 or so last night and went past the police at least 3 times without being stopped and invited to discuss social distancing.
If they do a reg check none of us are local to each other so that will confuse them and we can deny all knowledge of each other
MV 800rr brutale
MV 800 turismo veloce luso
So....is there a 3rd group or not??
Hi Jugs,TLS-Moose wrote: ↑Jun 16th, '20, 14:54Are you deliberately sending him elsewhereJug_Inspector wrote: ↑Jun 16th, '20, 12:44 Try this link.
https://app.box.com/s/w286kilmpnr0ntcxjh86qskaqfisryq6
That should be a small .itn file that you place in the itinerary folder on your TomTom.
Then when you open the software that "route" should be available to select as an itinerary, just select it and it should then calculate the route, if so check it carefully to make sure it has gone off track.![]()
I tried uploading it into the TomTom MyDrive website but it seems to require a GPX file (I thought that was a kawasaki). However, I'll try just dumping in to the tomtom directly as you say.
Try the link I did for Dave as that is a gpx file and will probably work better.
Just copied the itn file direct to the tom tom. INstalls a rout called sunday 21st June TomTom (2) and it just shows the initial location at Tiverton, not any stops or route...Kata wrote: ↑Jun 20th, '20, 19:37Hi Jugs,TLS-Moose wrote: ↑Jun 16th, '20, 14:54Are you deliberately sending him elsewhereJug_Inspector wrote: ↑Jun 16th, '20, 12:44 Try this link.
Yep that works.Jug_Inspector wrote: ↑Jun 20th, '20, 19:49 Try the link I did for Dave as that is a gpx file and will probably work better.
Well actually I imported it but just keeps the start and end points. TomTom software is utter pants. I ended up grabbing the coords listed for the points and just entering them. Thanks for giving it a go though.
Red5
- First Name: Nick
Hmm, glad I rode it this afternoon... Route works with bullet point guide and destinations with these new inventions called road signs.. They're frikkin excellent. They tell you what the road number is and where it's going and it means you're looking and observing what's around you rather than looking at a screen in way of your vision... Just saying
There's no way I want to get lost down there and end up "squealing like a pig" to a soundtrack of a Banjo or two.
Looking forward to it will be there for 9:15 start see you in the morning
- Guest user
Rain has stopped, sun is out, sky is blue
1960 BSA A10
1960 BSA A10
